    BlTouch reduce probing height
    985
    • peirof
      peirof last edited by
      Sometimes i am having errors when calibrate my delta, with a BlTouch, i have this error message, from DWC:
      • Error: Z probe was not triggered during probing move
      And calibration finish with a error...
      I understand, I'm not sure, that when you try a point in the calibration ... or start too high or not enough down the print head to find the bed
      I think I remember that this could be adjusted ... but I do not remember how.
      How do you adjust the distance that the head goes down to look for the bed?
      or
      How do I start the calibration closer to the bed?
      Thank you
      • peirof
        for the moment, i have changed this
        M558 P9 X0 Y0 Z1 H5 F120 T5000 ;
        To
        M558 P9 X0 Y0 Z1 H10 F120 T5000 ;
        If i have understand, H is the probing distance.... for the moment, with this avoid no triggers, but... i think head start probing moves far from bed... i am still interested in reduce this moves....
          That's correct, the M558 H parameter controls both the initial height above where the firmware thinks the bed ought to be at which probing starts, and the maximum probing distance (which is twice the H value). So if your delta printer is not well calibrated, or if you have changed something that may affect the calibration, use a large H value. When it is well-calibrated and you have copied the new parameters into config.g, you can use a smaller H value.
          fcwilt peirof 2 Replies Last reply Reply Quote 0
          • fcwilt
            fcwilt @dc42 last edited by
            @dc42 said in BlTouch reduce probing height:
            That should be in the docs for M558.
            I was wondering why things weren't working as I expected - now I know.
            Thanks.
            • peirof
              peirof @dc42 last edited by
              @dc42 Ok... But a What height start to probing? That it depends on the height at which it begins to taste. Of the dimensions of the printer?
                dc42 administrators @fcwilt last edited by
                @fcwilt said in BlTouch reduce probing height:
                Done, see https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M558_Set_Z_probe_type.
                fcwilt 1 Reply Last reply Reply Quote 0
                • fcwilt
                  You should get a raise for staying on top of things!
                  Thanks.
                  • peirof
                    I am using the wizard in web [http://www.escher3d.com/pages/wizards/wizardbed.php](link url) for generate bed.g, but when i try to select 12 and 6 halfway points, the wizard says a message that the limit of points its 16, but....
                    i am member of a facebook group of Duet in Tevo Little Monster, and have in files section a bed.g file that have 24 points, and add this gcode at start of file "M561; clear any bed transform"
                    Some answers/dudes:
                    • This extra points, 24-16=8, are taken into account for the calibration?
                    • The gcode, M561, its useful at start of bed.g? what is your function?
                    • In my case... when i calibrate, after calibrate, in the second calibration, the deviation is less. How many times its recommend calibrate?
                    • Calibration... After o before compensation? or After and before?
                      dc42 administrators @peirof last edited by dc42
                      @peirof, that wizard is a little old now. Does the wizard in the configurator at https://configurator.reprapfirmware.org/ allow you more points?
                      If you are using both auto calibration and bed compensation, you must run auto calibration before mesh bed probing.
                      Dougal1957 1 Reply Last reply Reply Quote 0
                      • Dougal1957
                        Dougal1957 @dc42 last edited by
                        @dc42 David
                        I have just checked the configurator and it will allow 17 points max (10 + 6 + centre) and only allow 3-7 factor calibration as well.
                        I still use the wizard on your site to be fair.
                        Doug (see you at TCT)
                        • peirof
                          the configurator inRepRAp configurator, allow the same points that the configurator in Escher Escher configurator. The dude, the same...
                          • The bed.g in Tevo Little Monster Duet user group, has 24 points.... these points are taken into accoint for calibration?
