How check termistor reading ok
I suspect that termistor I am using its not reading temperature correct...
What can i do for check termistor?
Thanks
You can always put them, protected, in melting ice to read if is showing 0C and then on boiling water to read the boiling temperature (100C at sea level and less if you are higher).
Another path would be finding a trusted reference temperature sensor to compare readings.
