Ft-5/Duet wifi/Cura Prints not homing properly, Help!
It looks like you have the origin set to the rear right of the printer, which is opposite of what it normally is.
Check this out and see if it makes sense.
https://drmrehorst.blogspot.com/2017/08/setting-up-3d-printers-origin.html
Phaedrux, that did the trick! I studied the info you linked and learned how printers and slicers align the bed and everything on it. I incorporated the knowledge and it made all the difference. A million thanks!
