Baby stepping not working
  • Didn't get much done last night looking at this,
    Sorry. My bed.g file is up there on a post from Oct 30.
    bed.g:
    ; bed.g
    ; generated by RepRapFirmware Configuration Tool on Tue Jun 26 2018 20:51:43 GMT-0600 (Mountain Daylight Time)
    ;M558 P0 ; unset Z probe for now...
    ; Probe the bed at 3 points (Right on top of the piezo sensors for now, will change later)
    M201 X950 Y600 Z5 E450
    G30 P0 X15.0 Y137.5 H0 Z-99999
    G30 P1 X205.0 Y137.5 H0 Z-99999 S2
    M201 X950 Y600 Z75 E450
    It is running this that seems to make the babystepping work. (Just clicking the "Auto Bed Compensation" button on the DWC.) I was able to confirm that neither G28 S1 nor G29 S2 makes a difference once babystepping works. I didn't get to checking if that makes it work before running the bed compensation.
    Thanks for the feedback. I will look into this next week.
  • And in typical fashion, it no longer fails.
    Over the weekend, I did some physical work on the printer, though I did not touch anything for Z movement. I replaced the carriage, and the heater block and nozzle. I did change my maximum X and Y movement speeds, acceleration and jerk (Higher acceleration, lower jerk) and noted that baby stepping worked first thing when I powered it up. I thought that I might have a clue, and restored the backup of the /sys folder that I had from before any changes, and it still works. I tested using the same gcode file (20mm cube with 25 loops of skirt) It now works with or without running the automatic bed compensation. I did not change any of the home files.
    I have no explanation, which kind of bothers me.
  • Not sure if there was any solution to this. I'm seeing the same issue. Baby stepping seems to do nothing. Executing it from the PanelDue
    WiFi Server Version: 1.21
    Web Interface Version: 1.22.6
    I am loading the meshmap in the config.g G29 S1
    Baby stepping is only 0.02mm at a time, so you may need a few presses to see anything. Also it isn't quite instant, it may take u to 1 move + 2 seconds half a second before it makes a difference.
    In firmware 2.02, if the printer is idle when you send the babystepping command, movement is instant.
  • Hi,
    I have the same issue.
    0.05 per dwc and 0.02 per Hardware Buttons. Offset is displayed correct in the dwc, no bed compensation, no min Z Limit and a G92 0.2 at the end of the homing files.
    Dwc, fw and wifi are the newest Version available.
    When i home Z, i can move Z up and down. Tried +/-2mm, there is no change in the layer. Like i said, dwc shows me the babystepping offset.
    I tried to change the M290 S Parameter to Z, there was an info in the gcode section of dozuki. No luck.
    Any idea?
    @torro said in Baby stepping not working:
    Any idea?
    Please describe what issue you are having. People have reported different issues in this thread. Also confirm that you are running firmware 2.02 (not a beta or RC version).
  • Hi there
    Duet Web Control 2.0.0-RC3
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.02(RTOS) (2018-12-24b1)
    Duet WiFi Server Version: 1.22
    When i increase/decrease Z per babystepping (0,05 in DWC or 0,02mm per programmed hardware buttons) the babystep offset is correctly shown in the DWC. BUT nothing happens with the first layer. i started a print and increased babystep offset to !!!2mm!!!, heighof the first layer didn´t change.
  • Hi,
    Just made a quick test.
    There is a difference visible, but i expected more. Few circles. the outer with baby stepping at 0, towards the middle, i increased per DWC in 0.1mm steps
