Cant upload any G-Code [SOLVED]
  • Hello,
    I have a Duet Wifi Board with a Duex 5 installed.
    When I try to upload any G-Code, I get this error message:
    I tried the following without any results:
    • Change Browser and Clean Cache
    • Backup all Files from the SD Card and run SD Card Formatter
    • Change SD Cards
    • Different PC to upload files
    I make my G-Code Files with Simplify 3D.
    My M122 report is here:
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DGM-9T6BU-FG3SN-6J1FG-3SJ6Q-KBWZG
    Used output buffers: 1 of 20 (6 max)
    Static ram: 28380
    Dynamic ram: 95772 of which 0 recycled
    Exception stack ram used: 332
    Never used ram: 6588
    Task NETWORK ready, free stack 396
    Task HEAT blocked, free stack 1256
    Task MAIN running, free stack 3568
    Last reset 00:00:14 ago, cause: software
    Last software reset at 2018-11-08 20:35, reason: User, spinning module GCodes, available RAM 6508 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    Free file entries: 10
    MCU temperature: min 19.0, current 19.2, max 19.4
    Supply voltage: min 11.8, current 11.9, max 11.9, under voltage events: 0, over voltage events: 0
    Driver 5: standstill, SG min/max not available
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Driver 9: standstill, SG min/max not available
    Expansion motor(s) stall indication: no
    Date/time: 2018-11-08 20:36:02
    Slowest loop: 4.28ms; fastest: 0.07ms
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 14.14ms; fastest: 0.01ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.21
      WiFi MAC address 84:f3:eb:83:2b:08
      WiFi Vcc 3.43, reset reason Power on
      WiFi flash size 4194304, free heap 17696
      WiFi IP address 192.168.178.88
      WiFi signal strength -69dBm, reconnections 0, sleep mode modem
      === Expansion ===
      DueX I2C errors 0
    Thankyou for your help
    Kind Regards
    Jan
  • What version of the DWC are you using?
    I think you may want to upgrade to the latest stable version of the firmware and DWC. To go settings, general tab, and click upload files button and upload the following two files one at a time. The duet will need to restart after the firmware.
    https://github.com/chrishamm/DuetWebControl/blob/master/DuetWebControl-1.22.4.zip
    https://github.com/dc42/RepRapFirmware/releases/download/2.01/Duet2CombinedFirmware.bin
    I also notice that your WIFI signal strength is quite low. Take a look at this and see if you can improve it. If the wifi signal is too low it may explain the uploads failing.
    https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
  • @phaedrux
    Thank you really much for the help.
    I updated the firmware and the web control and now everything works fine.
    Kind Regards
    Jan
