Question about M220 [SOLVED]
When using M220 to speed things up does it make any adjustments to the extrusion rate?
Thanks.
Yes the extrusion rate is adjusted so that the extrusion amount remains correct.
@dc42 said in Question about M220:
Thanks very much.
Perhaps that should be mentioned in the Gcode documentation section.
@fcwilt said in Question about M220 [SOLVED]:
Thanks very much.
Isn't it implied? Changing speed would be useless if the extrusion rate wasn't kelp in sync.
@dc42 said in Question about M220 [SOLVED]:
You are assuming most of us have that sort of knowledge.
It seemed to work so I assumed it was adjusting the extrusion rate but you know what they say about making assumptions.
