    Question about M375
    • fcwilt
      fcwilt last edited by
      Where in config.g should the M375 command be placed?
      Thanks.
        M375 is provided only for compatibility with other firmwares. Normally you would use G29 S1 instead. A common place to put it is at/near the end of homez.g and homeall.g files.
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @dc42 last edited by
          @dc42 said in Question about M375:
          M375 is provided only for compatibility with other firmwares. Normally you would use G29 S1 instead. A common place to put it is at/near the homez.g and homeall.g files.
          Good to know.
          Thank you.
            There was a typo in my previous reply, I omitted the "end of". Now corrected.
              Phaedrux Moderator @dc42 last edited by
              @dc42 Is it also acceptable to load the heightmap in config.g? Or should it only be loaded after homing Z?
                dc42 administrators @Phaedrux last edited by dc42
                @phaedrux said in Question about M375:
                With some firmware versions there was a problem if you homed Z using a Z probe when a height map was already loaded. So when using older firmware, you should not load a height map in config.g. In firmware 2.01 and later, it should be OK to.
                Please note, when running delta auto calibration or Z leadscrew levelling, there should be a M561 or G29 S2 command in bed.g to clear the height map first. So you may also want to load a height map at the end of the bed.g file.
