Possible Heater Chamber Code Bug
  • Hello,
    I think I may have discovered a code bug in relation to heater chamber.
    Long story short - when I powered up my chamber heater, it drew more power than I anticipated (voltmeter might have been off), and blew the duex 7A heater fuse.
    I starting immediately having some problems with the following error:
    Error: Short-to-ground on drivers 0 1 2 3 4 5 6 7 8 9
    Error: Over temperature shutdown on drivers 0 1 2 3 4 5 6 7 8 9
    When I replaced the fuse and started debugging, those ultimately went away. Not exactly sure what caused it.
    Now, however, the Duet will crash any time it reads the chamber g-code (M141 H5 S10). Heater still works and I can assign that channel to a regular heater and run it that way.
    Here's the diagnostics:
    2‎:‎08‎:‎17‎ ‎PM
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet Ethernet 1.02 or later + DueX5
    Board ID: 08DGM-9T6BU-FG3SN-6J1FL-3SJ6M-18WBG
    Used output buffers: 3 of 20 (9 max)
    Static ram: 28380
    Dynamic ram: 96380 of which 28 recycled
    Exception stack ram used: 332
    Never used ram: 5952
    Task NETWORK ready, free stack 460
    Task HEAT blocked, free stack 1176
    Task MAIN running, free stack 3560
    Last reset 00:00:23 ago, cause: power up
    Last software reset at 2018-11-19 14:07, reason: Hard fault, spinning module GCodes, available RAM 5484 bytes (slot 3)
    Software reset code 0x4033 HFSR 0x40000000, CFSR 0x01000000, ICSR 0x0441f803, BFAR 0xe000ed38, SP 0x20004964
    Stack: 0041e831 0041f218 21000000 20008ef0 20004990 00000001 0043a2cd 0000000a 20000178 200001d8 0000008d 00000000 20004c8c 20013ec8 a5a5a5a5 20002b78 0044c6fb 200001d8 00000000 0000000a 2000aef0 2000a428 2000aef0 0000008d
    Error status: 0
    Free file entries: 10
    SD card longest block write time: 5.0ms
    MCU temperature: min 28.4, current 29.9, max 30.2
    Supply voltage: min 24.4, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0
    Driver 5: standstill, SG min/max not available
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Driver 9: standstill, SG min/max not available
    Expansion motor(s) stall indication: no
    Date/time: 2018-11-19 14:08:14
    Slowest loop: 14.57ms; fastest: 0.07ms
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 14.90ms; fastest: 0.01ms
    HTTP sessions: 1 of 8
    Interface state: 5
    === Expansion ===
    DueX I2C errors 0
    @tlas said in Possible Heater Chamber Code Bug:
    I can see why that happens. The VIN monitor reports that the voltage is in the operating range of the stepper drivers, so they ought to respond correctly to SPI communications; but in fact they have no power because of the blown fuse.
    Please install firmware 2.02RC4. If the problem still happens, post the M122 report again.
