    Experimental firmware release 1.17c+1
    Firmware installation
    10
    41
    4564
      I've just put this in the Edge release folder for Duet WiFi of github. Change list:
      • Removed GCC O3 optimisation pragmas because they inhibited function inlining, so they made performance worse instead of better
      • Refactored step interrupt code for speed up
      • Implemented G2 and G3 arc movement commands
      • Firmware retraction/unretraction now defaults to 2.0/2.0 instead of 1.0/2.0
      • Bug fix: absolute extrusion didn't work when using a mixing tool
      The maximum step pulse rate achieveable is now 355kHz with a single motor running, and 190kHz with three motors running simultaneously. In practice this means that any belt-driven Cartesian or CoreXY printer using 1.8deg motors should be able to achieve 300mm/sec speed with 128x microstepping. It's not quite so good on a delta, but I've increased my delta (which has 0.9deg motors) to 64x microstepping and it seems to be working well.
      The G2 and G3 commands will be of most use in CNC applications. I've supported the Z parameter too, so you can use it to generate corkscrew movements. The segment length is currently fixed at 0.2mm.
      This release is designated as experimental because there is more testing to do of the G2/G3 commands, in particular on IDEX printers.
      • InSanity
        InSanity last edited by
        Awesome, will try it out.
        Edit: So far so good.
        Thanks,
        Jeff
        Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
        • InSanity
          I can't speak on the arcs G2 and G3 however the normal functions are working really well. I switched everything to 128x up from the 64x and I almost feel it's running faster…even though I know it's not. Smoother maybe...IDK. In any event it's quieter, 64x is nice...but not as nice. I'm assuming 256x will probably do really well for me now ?
          Thanks,
          Jeff
          • Jackal
            Jackal last edited by
            Thanks for the update.
            I am currently using 16x microstepping with interpolation on my 0.9deg motors delta, should I switch to 64x microstepping on this firmware?
            What will be the difference?
              That's up to you! Try both and see what works best.
              • deckingman
                deckingman last edited by
                @dc42,
                Following on from the M207 thing that was unearthed in the other thread. I just installed this firmware (1.17c+1) and ran a few quick tests. I was a bit concerned that when we had the over unretraction (recovery) issue, it seemed that only extruders 0 and 2 were affected. It seems that this is still the case. i.e setting the R parameter only affects extruders 0 and 2 on my machine - extruder1 is unaffected.
                That is to say if I do M207 S2.0 R2.0 F3000, then do M207 on it's own it is reported that retraction is 2.0 and unretract is 4.0 as expected. So then doing G10 followed by G11 whilst observing the extruder gear positions, the difference in position should be obvious. It is for extruders 0 and 2 but extruder 1 always returns to the same position when doing a G10 followed by a G11, even though G10 should be 2.0mm and G11 should be 4.0mm (G10 looks right and is the same for all 3 extruders).
                This is the behaviour that I observed when printing using 1.17c.
                Sorry to be the bearer of bad tidings. It's not a big issue for me because I don't wish to use any extra recovery from retract nso now that it's set to zero, I can print OK.
                  Hi Ian,
                  That's very odd, because the code applies the same retraction and un-retraction values to all extruders assigned to the tool. Please can you generate the debug output I asked for earlier, using 1.17c+1 and a non-zero R value, doing a G10 followed by a G11.
                  Thanks - David
                    PS - also, please try a negative R value and see how it affects the 3 extruders.
                    • deckingman
                      David,
                      This is weird. I can't reproduce the problem. I know I didn't dream it because I witnessed it and filmed it. It's plain as can be on the last minute or so of the video that extruders 0 and 2 had too much recovery but extruder 1 was unaffected. So I knew what to look for and sure enough, it was there earlier. However, now it isn't. I tried powering off the machine, doing a restart and testing it before doing anything else but it still worked as expected. Thoughts?
                      BTW, negative R values work as expected on all 3 extruders (at least, it did when I tried it).
                      • InSanity
                        @Jackal:
                        Chances are your not going to see any real resolution increase going from 16x to 64x because you are already running good 0.9 deg motors. In my case I'm running 1.8 deg/step motors with 17 tooth pulleys and I can ever so slightly see an improvement going above 16x stepping. This is one of those topics where someone will point out.."that's just impossible to see". Whatever the case I would suggest trying 128x as it's quieter then 64x at least in my case.
                        If you change your microstepping be sure to set your steps per mm and then the microstepping values. M92 is steps at 16x and then M350 to have it auto adjust.
                        In my case:
                        M92 X94.12 Y94.12 Z400 ; set axis steps/mm
                        M92 E200.7238:200.7238 ; set extruder 0 and 1 steps/mm
                        M350 X128 Y128 Z128 E128:128 ; set microstepping
                        Jeff
                        • DjDemonD
                          DjDemonD last edited by
                          I just had an issue using this firmware 1.17c+1. I am using slic3r generated retraction but just printing a cube, at the first retract it did a massive retraction seemingly pulling the filament back 20mm+ (I've never seen the extruder turn that fast before). I abandoned the print at the next one.
                          Uploaded 1.17c - printed the same object from the sd card, printing normally.
                          www.precisionpiezo.co.uk
                            @DjDemonD:
                            What type of hot end are you using? The only change in that area that I made in 1.17c+1 should only affect mixing hot ends.
                            • Jackal
                              @DjDemonD:
                              I think I am having similar problem with the extruder on 1.17c+1. First I thought it was due to messing with microstepping, but resetting to leave it at 16x still caused the extruder motor to move erratically. I have reverted to 1.17c to print, maybe I will try investigate further later.
                              • InSanity
                                Weird, I did a print that sucked down about 250g of filament with this firmware and noticed no issues at all with the extruder. Being a software engineer I know how this goes, I'm sure it'll get resolved.
                                • DjDemonD
                                  @dc42:
                                  @DjDemonD:
                                  Titan extruder, 20mm nema 17 pancake stepper, into a genuine e3d v6 in flying configuration.
                                  • curieos
                                    curieos last edited by
                                    I noticed a similar issue when upgrading to the first 1.17 release. I tied it to using incremental vs absolute extruder positioning. I just switched over to absolute in KISS and I didn't have any problems.
                                    Owner of the one and only Birch MAX V3.2
                                      I've released another minor update, 1.17c+2. The changes are:
                                      • Fixed a bug in the interpretation of the G2/G3 I and J parameters (they are supposed to be relative always)
                                      • If a Hard Fault exception occurs, the software reset data now includes additional status information to help track down the cause.
                                      I recall that a couple of users have reported unexpected resets, with a software reset code of the form xx3x subsequently reported by M122. If you are one of them, please install this release in case it happens again.
                                      • sLpFhaWK
                                        sLpFhaWK last edited by
                                        So I installed this on my Kossel delta, and it's been printing fine with no issues.
                                        I installed it on my Rostock Max V2 and I am having nothing but issues. I just did a 19 hour print on 1.16 beta 10 and it's been printing beautifully since I installed it.
                                        Now when I try to print anything it seems the retraction has quadrupled or something silly like that. What used to be a 4mm retraction is taking it back 16mm and i'm guessing but I've watched the retractions before and the knob was 1/4 turn now it's atleast 1 full turn.
                                        But my Kossel seems to be unaffected with this same issue. Both printers have Duet Wifi's with Web interface 1.14a.
                                        -sLpFhaWK
                                        Ultibots K250v
                                        Rostock Max v2 Soon to be Full MetalMax
                                        Mini Kossel
                                          Is that 4mm of firmware retraction, or is the 4mm configured in the slicer?
                                          • sLpFhaWK
                                            DC42 I flashed to 1.17c and it fixed the problem with the same GCODE that I had sliced on the experimental version.
                                            4mm is what is set in the slicer but when it would retract it would only do say 1/4 of the knob retracting, when I was on experimental it would do a full revolution for the same retraction.
                                            I don't know what caused it, but that was my issue, I am also experiencing another issue as well. On the same printer ever since I flashed my web interface isn't updating, I connect it gives me a read out and then thats where it sits, no updates on temps, if the machine is busy extracting or performing other functions.
                                            That is at idle, if I'm printing something it seems to be ok.
                                            -sLpFhaWK
                                            Ultibots K250v
                                            Mini Kossel
                                              Whenever the web interface stops updating, I recommend the following:
                                              1. Make sure you have a compatible version of the web interface. With 1.17c firmware you should use DWC 1.14a.
                                              2. In Firefox or Chrome press control-shift-J to get the debugging console. Chances are you will find an exception report.
                                              • Hugues
                                                Hugues last edited by
                                                With your first release I didn't get any problem, and when I removed the interpolation I setup a crazy speed without bug on retract ! Really good work !
                                                https://youtu.be/XhwdI2oOlKI
                                                • sLpFhaWK
                                                  Okay on Beta 10 1.16 I had the older web interface, I think 1.12 it was and I had no issues, I am using 1.17c and 1.14a web interface..
                                                  I am using chrome, I hit control shift J and I got this.
                                                  dwc.js:2686 Uncaught TypeError: Cannot read property 'sort' of undefined
                                                  at Object.success (dwc.js:2686)
                                                  at i (dwc.js:2)
                                                  at Object.fireWith [as resolveWith] (dwc.js:2)
                                                  at A (dwc.js:4)
                                                  at XMLHttpRequest. <anonymous>(dwc.js:4)
                                                  I don't know how to fix it, what needs to be done?
                                                  And also to add, on my Kossel which I am on experimental and 1.14a I am having no issues with Chrome.</anonymous>
                                                  -sLpFhaWK
                                                  Ultibots K250v
                                                  Mini Kossel
                                                    We really need chrishamm to take a look at this, but looking at the code, I think the Duet didn't return a files list when one was expected. Do you have folders /sys, /gcodes and /macros on your SD card?
                                                    • DjDemonD
                                                      Any thoughts on the retraction issue? I haven't tried the very latest release but I was getting a massive retract instead of tiny one with 1.17c+1. I will try +2 if there is a fix for this in it.
