    layer heights in print status web interface
    • r123
      r123 last edited by
      Running a print from S3d with two different layer heights.
      The bottom part of the part was 0.2mm and so the web interface is displaying:
      Layer Height 0.15mm/0.2mm (the first layer height was set to 75% in S3d slicer).
      Now we're well into the top part of the part which has a layer height of 0.1mm but the web interface continues to display as before.
      This is not a big deal but if had a choice (given limited screen space) would rather have the web interface display the CURRENT layer height.
      Any views on this?
        Which firmware version? I made a change to the layer detection in 2.02RC4 or RC5, I forget which.
        • r123
          r123 last edited by
          fair enough
          2.01(RTOS) (2018-07-26b2)
          • mrac1
            mrac1 last edited by mrac1
            If you change something, it also shows the z-hop height as first layer height. Edit - not S3D, Slic3r PE (2.02 RC5)
