Independent Z moves
@wmmc01 said in Independent Z moves:
G1 Z2 F6000 ; NEW Lift Z relatively to current position
You need to either add parameter S2 to that command, or use M584 H0 in config.g to allow axis movement before homing. This is nothing to do with dual Z motors, it has been required since firmware 2.01.
OK, thanks. I copied from this example: https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18?lang=en. Not sure if there is a way to correct/edit that. I added a comment regarding this.
Thanks for your help!
Thanks, I can't edit the images because they are hosted by someone else, but I have added two notes in the instructions steps.
New problem. In relative mode I can move Z (Z & U) a distance without an issue. The both move the same amount at the same speed. However when I Home Z, U moves faster and quickly jams. The steppers are identical.
homez.g:
; homez.g
; called to home the Z axis
; NEW indicates lines that support dual Z end stops
; generated by RepRapFirmware Configuration Tool v2 on Tue Dec 18 2018 16:44:11 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 Z2 S2 F6000 ; NEW Lift Z relatively to current position
; NEW split Z motor control to Z and U
; for it to work we have to show U (param P4) in the UI
M584 Z2 U3 P4 ; NEW
; NEW Move Z and U down until the switches triggers
G1 S1 Z-385 U-385 F1000 ;New edited to 385
; NEW back to combined axes and hidden U
M584 Z2:3 P3 ; NEW
; NEW Back to absolute positioning
G90 ;NEW
; G1 S1 Z-385 F1800 ; OLD move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
G91 ; relative positioning uncommented for NEW
G1 S2 Z5 F100 ; lift Z relative to current position uncommented for NEW
G90 ; absolute positioning uncommented for NEWDRIVES Portion of config.g:
M569 P0 S1 ; Drive 0 goes forwards Y Homes to the Front X Homes to the Right
M569 P1 S0 ; Drive 1 goes BACKWARDS Y Homes to the Front X Homes to the Right
M569 P4 S1 ; NEW Drive 4 goes forwards
;M584 X0 Y1 Z2 E4 ; OLD M584 is next section Apply custom drive mapping
M350 X32 Y32 Z32 U32 E32 I0 ; NEW Configure microstepping without interpolation NEW Added U32
M92 X160.00 Y160.00 Z1600.00 U1600.00 E476.50 ; NEW Set steps per mm NEW Added U1600.00 Changed steps per mm to 1600 was 3200
M566 X900.00 Y900.00 Z12.00 U12.00 E120.00 ; NEW Set maximum instantaneous speed changes (mm/min) NEW Added U
M203 X12000.00 Y12000.00 Z600.00 U600.00 E1200.00 ; NEW Set maximum speeds (mm/min) NEW Added U Changed Max Speed for Z/U to 600 was 6000
M201 X500.00 Y500.00 Z250.00 U250.00 E250.00 ; NEW Set accelerations (mm/s^2) NEW Added U
M906 X800.00 Y800.00 Z800.00 U800.00 E800.00 I30 ; NEW Set motor currents (mA) and motor idle factor in per cent NEW Added U
M84 S30 ; Set idle timeout;DUAL Z NEW
M584 X0 Y1 Z2:3 U3 E4 P3 ; NEW Line Creates Dual Z by adding U as second Z -
This sounds very much like a bug that I fixed in firmware 2.02. Which firmware version are you using?
I may have figured it out. M584 was previously below all the other Drive info. I moved it to below the last M569, and fixed my steps/mm for Z, and all looks fine now. But I'll keep testing to confirm. Thanks for your help! Really appreciate your quick responses!
BTW FW: 2.02(RTOS) (2018-12-24b1)
Best Regards, Bill
