    Some Z-offset error after bed replacement.
    449
    • janjoh
      janjoh last edited by
      So, this is a followup of https://forum.duet3d.com/topic/8340/replaced-bed-now-have-some-geometry-issues
      But since it is a separate issue, i figured I would make a separate topic for it.
      Basically, after my re-build, if i tram my printer to Z0 i am still at about 0.2mm over the bed. A 0.15mm feeler blade slides freely under nozzle, but a 0.20 blade hits the nozzle ever so lightly. I can slide the 0.2 under the nozzle without feeling any noticable resistance. I'm running a Smart Effector on 2.02
      I really can not understand what (most likely silly) thing that I have missed this time. Seem almost like a probe offset thing, but if so I think I would have had similar issues with my previous bed?
      config.g
      ; generated by RepRapFirmware Configuration Tool on Sat Mar 10 2018 00:14:59 GMT+0100 (W. Europe Standard Time)
      M665 R179.489 L360.2 B150 H451 X0.746 Y0.761 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.85 Y-0.81 Z-0.04 A0 B0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PFullMetalDelta ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S1 ; Drive 0 X goes forwards
      M569 P1 S1 ; Drive 1 Y goes forwards
      M569 P2 S1 ; Drive 2 Z goes forwards
      M569 P3 S0 ; Drive 3 E0 goes backwards, Zesty Nimble
      ;M569 P3 S1 ; Drive 3 E0 goes backwards, Titan Extruder
      M92 X200 Y200 Z200
      ;M92 E418.5 ; Set steps per mm (Titan)
      M92 E2855 ; Set steps per mm (Zesty)
      ;M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min) Titan
      M566 X1200 Y1200 Z1200 E40 ; Set maximum instantaneous speed changes (mm/min) Zesty
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      ;M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2) Titan
      M201 X1000 Y1000 Z1000 E120 ; Set accelerations (mm/s^2) Zesty
      M906 X1000 Y1000 Z1000 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P5 R0.4 F1000 H5 ; Smart Effector
      G31 P100 X0 Y0 Z-0.1
      M557 R148 S20 ; Define mesh grid
      ;M305 P0 T99670 B4471 C8.262085e-8 R4700 ; Set thermistor + ADC parameters for heater 0 Keenovo heater
      M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0 Clever3d heater
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      ;M106 P0 S0 I0 F10 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P0 S0 I1 F100 H-1 L0.3 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      ;M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 I1 H100:101 T45:55 L0.3
      M563 P0 D0 H1 ; Define tool 0
      M572 D0 S0.03 ; Pressure advance
      M912 P0 S-22 ; Temperature offset.
      ; Custom settings are configured
      M501
      ;Load mesh calibration
      G29 S1
      config-override.g
      ; Delta parameters
      M665 L360.200 R179.529 H453.948 B150.0 X0.135 Y-0.070 Z0.000
      M666 X-0.496 Y0.126 Z0.370 A0.00 B0.00
      ; Heater model parameters
      M307 H0 A241.5 C325.9 D1.5 S1.00 V12.1 B0
      M307 H1 A263.0 C111.3 D6.3 S1.00 V12.1 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        Did you remeasure your z probe trigger height again after replacing the bed?
        janjoh 2 Replies Last reply Reply Quote 0
        • janjoh
          janjoh @Phaedrux last edited by
          @phaedrux said in Some Z-offset error after bed replacement.:
          Well, thats part of the issue, even with M564 S0 i am not able to drive Z past 0.
          (Following https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe)
          • janjoh
            Aha!
            This bit me!
            https://github.com/chrishamm/DuetWebControl/issues/99
            So, now i could disable limits with S564 S0
            I get pretty consistant trigger heights now of -0.176mm (varies between -0.174 and -0.177 when running approx 25 tests)
            Then i read
            Once you are satisfied with your trigger height result (should be between 0 and 1mm, depending on your printer), open your config.g file (this can be found in your DuetWebControl), find the G31 command and enter your trigger height as a negative value in the Z parameter (ex. G31 X0 Y0 Z-.43).
            Since i get a negative trigger height, does that mean that I should enter a positive value there?
            And also... When running G30 S-1 it says "Probe the bed" so i assume that i should have removed my paper?
            fotomas created this issue in chrishamm/DuetWebControl
            closed Sending G-Code with send button #99
              The smart effector is a nozzle contact type probe, so it would be expected to get a negative trigger height, since it has to push into the bed slightly in order to trigger. So your G31 Z value would be negative.
              If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
              You've just found one reason I dislike using paper to get the nozzle close to the bed. When you use paper you need to know how thick the paper is, and how hard did the nozzle press into it? How much friction is enough or too much?
              I find it far more accurate to just shine a light behind the printer and watch while lowering the nozzle. You can easily see the gap disappear when it touches.
              In contrast, it's quite easy to see the difference between 0.05mm by eye. Even with such a small gap the daylight between the nozzle and bed is obvious.
              janjoh 1 Reply Last reply Reply Quote 0
              • janjoh
                Well, I have a set of feeler gauges.
                But regardless of that... GOt any hints on how i should proceed in my case? 🙂
                  Phaedrux Moderator @janjoh last edited by
                  @janjoh What issue are you still having? It sounded like you were able to get a proper z probe trigger height measurement.
                  • janjoh
                    janjoh @Phaedrux last edited by janjoh
                    Well, as i said. The guide says to enter the offset as a negative value, and that the hegith is usually 0 to 1mm . But i am getting a negative value on my readings. Does that mean i should put in a POSITIVE trigger value in my G31?
                    Because if i enter -0.176 in G31, and reset my machine, I end up back where the head will be at about 0.2mm over the bed when the machine reads Z0
                    Edit: Crap.. Starting to regret the "New" WebControl. Mesh compensation didnt disable propery. I think I've got it now.. lesseeeee
