Error: Bad command
Hi.. I am newbie with my duet3D Ethernet
I generated a g-code from ArtCam, then I sent to my Duet3D The system reportError: Bad command: Y1.679
Error: Bad command: X0.002
Error: Bad command: Y3.279
Error: Bad command: X83.046
Error: Bad command: Y4.878
Error: Bad command: Y6.477
Error: Bad command: Y8.076
Error: Bad command: Y9.675
Error: Bad command: X83.046Anybody to help me ?
PD.
This is my current firmware
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later -
Can you post the actual gcode you were trying to run? It kind of looks like you might need to be in CNC mode so you can use gcode formatted with coordinates but without a G1/G0 for each line.
https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_CNC_machine
Hi, I’m finishing a powermill, featurecam, artcam postprocessor for RRF. I think I’ll finish it after new year. It’s already working, I just want it to correctly output G2 and G3 arcs and be sure it doesn’t output any canned cycle since those are not supported.
