Solved Warranty replacement fried?
I don't have one laying around but I can order a new Meanwell and try it .I am going to try the PSU I have on my Smoothieboard and if it works I highly doubt it's the PSU.
Set your multimeter to 10A scale and connect it in series with the Duet. If there is a short, it should jump (above 10A most likely). If the PSU is at fault you will see much less current than 10A.
Crynool to my disbelief it was the PSU.You my friend hit the nail on the head.I swapped out my psu for a friends and it is working just fine so I am going to order one today.Thanks for all the help
Glad you sorted it out
