M106 Maximum Fan Speed Setting - unproportional
I was installing berd-air and found that driving at more than 50% not only does not help, but harms the print and produces lots of noise.
on our has WiKi M106 L and X parameters (min and max fan speed).
my config has this lineM106 P1 L10 X150 F22500 S0 H-1 B0.1
M106 P1 reports
Fan 1 pin: F1, frequency: 22500Hz, speed: 0%, min: 7%, max: 58%, blip: 0.10, inverted: noQuestions:
(1) why X parameter is not proportional? i.e. with my config line once i run M106 P1 S85 (that should me 50% median for my limits.However P1 reports 33% of max, that is in fact 33% of 255, not 150. I suggest to re-map 100% to limited maximum with scale length of max - min
doing so will ease working with slicers without re-calculating what % of cooling to put in.(2) why fan switches on for 1-2 seconds during reboot cycle?
(3) fan "remembers" its speed before reboot and continues to run. in other words, if fan was running it continues to run unless i put S0 in confing. is it by design?thanks!
P.S. similar treads are closed for commenting .
@c310 said in M106 Maximum Fan Speed Setting - unproportional:
The S parameter is always on a scale of 0-1 (if <= 1) or 0-255 (if > 1). We could change it, but that would make it behave differently from other firmwares.
Because we intend Fan 1 output to be used for the hot end heatsink fan, so it defaults to on for safety (e.g. if you upgrade the firmware while the hot end is hot, you don't want to end up with a filament jam).
Are you sure that fans
do notremember their speed across a reboot? If so, that isn't intentional. -
@dc42 said in M106 Maximum Fan Speed Setting - unproportional:
i understand the difference. however is seems logical for me to "fit" 0...100% scale in between hardware limits that are set by L and X parameters declared in config. In other words, in config we set limits, and when slicer sets fan (for example) at 50% that 50% should be median between L and X.
in current configuration if i set Lo and High values slicer generated M106 are irrelevant to real scale .So, L and X are setting hardware limitations, S should be controlling speed in between those limits.
That's a debatable point.
Slicers tend to use values such as M106 S0.5 meaning run fan at half speed. If the firmware were changed as you suggest, then that "0.5" takes on a completely different meaning. In fact it become meaningless because the upper and lower limits could be set to anything. So 50% fan speed could be actually be 10% of the fan's speed. But if the limits were changed again, then that 50% could be 80% of the fan's actual speed.
If the firmware was modified as you suggest, I could foresee many users wanting it to be changed back to how it was (me for one).
Why not?
This could work nice with filaments profile, so you are able to set cooling from filament profile in Duet by just scaling it.
I even though this is how it works, unfortunately not :/.
For examples to be more explanatory:- for ABS I would set M106 L0.0 X0.2
- for PLA I would set M106 L0.8 X1.0
- for PET-G I would set M106 L0.1 X1.0
Maybe add an option to M106 to enable scaling.
@dragonn said in M106 Maximum Fan Speed Setting - unproportional:
I think there is no right or wrong way here. Both variants have their place. I think an option to enable scaling would be a good idea.
Changes are minor to achieve this. @dc42: What do you think about an option? I can implement that quite easily. Hardest part as always: which parameter to use.
@wilriker Yup. Optional would be good. More chance of pleasing "all of the people, all of the time" rather than "some of the people all of time" or "all of the people some of the time".
Have this implemented and ready to create a PR if @dc42 is OK with the basic idea.
Only one open question: what should the fan status report as the set speed? Physical or logical speed? I have it implemented as physical speed but swapping it to logical is just deleting one line of code.
BTW: I used
Wnnn
as the parameter for now. Like "W
hatever you want the fan to behave". -
@wilriker logical, it need to report the same as you set. Otherwise it will confuse paneldue and DWC
@dragonn You are right - also because this could have potentially led to side effects where the fan suddenly runs slower than commanded. So changed this back to logical/commanded speed.
@wilriker said in M106 Maximum Fan Speed Setting - unproportional:
Optional
@deckingman said in M106 Maximum Fan Speed Setting - unproportional:
Optional
Seriously?
No, but really seriously: that would make things probably a little awkward and confusing. Example: you have the fan set to
M106 P2 L0 X0.5 W1
(i.e. min 0%, max 50%, scaling on) and then pull the speed slider in DWC all the way to 100% - once RRF would have executed that command the slider would jump back to 50%.I could add it as a separate information to
M106
status output though. -
Now what would be cool would be to have fan speed act in proportion to filament volume flow flow rate - I'd settle for extruder speed.
If you've' ever played around with large nozzles or multiple melt chambers and high speeds, then you'd know that you need much more cooling than for low volume flow rates.
Optional
Seriously?
M106 P2 L0 X0.5 W1
M106
status output though.That's the problem with effectively having two speed ranges. 0 to 100% of what the fan is capable of and 0 to 100% of some range within that range. Which one do you report?
Implementation complexity would be the same for both ways since the firmware always knows the flow rate because that will be converted into extruder movement.
But that is the easy part here.
Ref which value to report: I think it is mandatory to internally work with the commanded (logical) value. Otherwise you would have controls that jump around and cannot reach certain values - which is what we already have right now with min and max values...
The longer I think about it the less of an opinion I have.
EDIT: I got totally confused so I had to revert back to check: right now it will report whatever the user has commanded. If you tell the fan to run at 100% but set max to 50% it will still report 100% although the fan is turning at 50% speed.
@wilriker yeah, this is how it schould work.
@wilriker i see it this way:
like @dragonn suggested
M106 Laaa Xbbb in config.g or in filaments sets hardware limits.once limits are set - DWC should treat them as end parts of 0...100% scale.
so, if in DWC I drag fan to 100% physically it it would be set to bbb value from related config.this "logical scaling" behaviour can be initiated by W1 option, with W0 (no scaling) being default.
Reporting for DWC can show both values (physical and logical)
@c310 I came to that conclusion also now. Since RRF is reporting the commanded value to the outside ever since I won't change that behavior. But I will add the value for physical speed to
M106 Pnnn
output.Since there is no good way (I can think of) to permanently show both values in DWC as well as it would tremendously increase complexity of this change I will not even attempt to show both values any other way than described in the paragraph above.
I just submitted this pull request. Now it is up to @dc42 to accept or reject it.
@dc42 we have the best firmware
lets add some
power options to it
