Thermistor fail situation
Hello everyone
I've recently encountered an event of one of the thermistor wire breaking. Thankfully watchdog worked perfectly- hotend cartridge was shut off. Also I've discovered a resurrect.g file and it would be really nice to get a use of it (+16hrs print at 0.04mm). Unfortunately as the hotend was shut, the bed also turned off which result in print detachmentIs there possibility in firmware to leave heatbed on even if heater error occured?
