    SOLVED Web interface can load, but can't connect to Duet firmware?
    • froggyman
      froggyman last edited by
      I was able to "successfully" configure the wifi on my new Duet2 WiFi board. I can load the web interface at its IP address without any trouble, but when I try to press the "connect" button, the web interface errors out saying "Could not establish a connection to the Duet firmware!". It'll usually say that it's connected for a second or two though first.
      Any suggestions for getting this to work?
      Here's the results from running the M122 (diagnostic) command:
      ok
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SN-6JKD0-3S46J-9UYHD
      Used output buffers: 1 of 20 (10 max)
      Static ram: 28380
      Dynamic ram: 96148 of which 16 recycled
      Exception stack ram used: 304
      Never used ram: 6224
      Task NETWORK ready, free stack 628
      Task HEAT blocked, free stack 928
      Task MAIN running, free stack 3656
      Last reset 00:08:12 ago, cause: watchdog
      Last software reset details not available
      Error status: 0
      Free file entries: 10
      MCU temperature: min 28.7, current 28.9, max 28.9
      Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Slowest loop: 5.12ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.18ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 660, notready 0, noresp 0
        WiFi firmware version 1.21
        WiFi MAC address 84:f3:eb:42:af:42
        WiFi Vcc 3.40, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 12872
        WiFi IP address 192.168.0.15
        WiFi signal strength -39dBm, reconnections 0, sleep mode modem
        === Expansion ===
        ok
        dc42 administrators @froggyman last edited by
        @froggyman said in Web interface can load, but can't connect to Duet firmware?:
        Please try updating the wifi firmware to 1.22 or 1.23beta. As you don't have a good wifi connection yet, you will need to:
        • Download the new DuetWiFiserver.bin file
        • Put the SD card in a PC and copy the new DuetWiFiServer.bin file into the /sys folder, overwriting the one already there
        • Eject/Safely Remove the SD card from the PC and put it back in the Duet
        • Start the Duet and send M997 S1 to install the new WiFi firmware
        • froggyman
          For the people of the future, I was able to update the firmware was suggested, but I still had the same failure of not being able to connect with the web interface.
          Changing my WiFi network channel to channel 6 was able to solve the issue though, which was suggested in another troubleshooting guide I found.
