filament change
Hi, is there a temporary way to drop the working temperature of the hot end in the filament-change.g file so I can remove the filament easily on my direct extruder. If so, what is the command to set it back to printing temperature afterwards?
I suppose you could set the standby and active temperatures using
G10 P R S
. Then take the tool to inactive in your pause/filament-change macro, and then make the tool active again and useM116
to wait for temp.https://duet3d.dozuki.com/Wiki/Gcode#Section_G10_Tool_Offset
Ok cheers, I will give that a try.
