    Duex 5 generic I/O question
    455
    • Marco Bona
      Marco Bona last edited by
      I want to configure an emergency button on a duex5 input. I have all the limit switches engaged, how could I do? Can I use a generic duex input which when activated calls the M112 command?
      Thank you
      Marco
        Are you using the 2 endstop inputs on the CONN_LCD connector? If not then I suggest you use one of those instead.
        • Marco Bona
          Thanks for the answer, the LCD connector is free, the pins are 2 and 3? Is there a reference guide for the configuration?
          Thanks
          • Marco Bona
            Sorry, pin 10 (ENC_A) and pin 11(ENC_B), to activate the limit switch is correct the command M581 E10 S1 T0 C0?
              dc42 administrators @Marco Bona last edited by
              @marco-bona said in Duex 5 generic I/O question:
              In the M581 command, endstops 0 to 11 are X Y Z then E0 to E8. So you would use E7 or E8 in M581 depending on which one you connect to.
              In a future 2.03beta (probably the next one) this may change, because we are moving to logical pin numbering and flexible pin allocation.
              • Marco Bona
                I did not understand what I should use to activate the limit switch on CONN_LCD
                  Connect the switch between one of the endstop inputs on CONN_LCD and ground. The CONN_LCD pinout is at https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers.
                  • Marco Bona
                    Sorry David, I explained myself wrongly, in the firmware which command should I use to activate the pin on CONN_LCD because it does not currently work and I do not know how to enable it as a limit switch
                      Unless you are using very old firmware, it should already be configured as an endstop input, and the M581 command with E7 or E8 in it should just work.
                      • Marco Bona
                        It works perfectly!!
                        Thanks
