    Fan setting ?
    • Rudy2A
      Rudy2A last edited by
      I'm having a problem with a fan.
      My fan in Fan0 (the one that serves to cool the material) whistles (like a light continuous beep) as soon as it is connected!
      This same fan does not whistle on another machine (Marlin).
      Its order under Duet3D is as follows: M106 P0 S0.4 I0 F500 H-1
      I connected it on Fan2 (M106 P2 S0.4 I0 F500 H-1) and it's always the same?
      I thought of lowering the HZ (Fxxx). This slightly improves this whistling, but it is still present.
      My fan is 12v, my power supply is 12V and Jumper Select is on VIN?
      An idea? Thank you !
      • deckingman
        deckingman @Rudy2A last edited by
        @rudy2a
        It is usual to set the part cooling fan initially to be off in your configuration file, then let the slicer add the fan speed commands to the gcode file. You have S0.4 which means that the fan will run at 40% speed as soon as the machine boots. So changing it to S0.0 will turn it off.
        Rudy2A 1 Reply Last reply Reply Quote 1
        • Rudy2A
          Rudy2A @deckingman last edited by
          @deckingman
          Super it works!
          Thanks to you...
          • bot
            bot last edited by
            The RRF config tool seems to generate these odd fan commands in config.g. It seems to be intending to set the minimum PWM setting (L parameter) but instead generating it as the S parameter.
            *not actually a robot
              It appears to me that the configurator defaults fan 0 to running at 30% at startup. I can't see any reason for that, so I will have it changed.
