    possible web control firmware glitch - 2.02
    1.0k
    • Mentaluproarundefined
      Mentaluproar
      Same issue I had from an earlier post, but the thread is now locked so I'm posting a new one.
      My duet was happily printing a long print. I opened up my laptop. It was previously on the duet webUI. When the wifi reconnected, it reloaded the page, which caused it to halt the print and repeat a bunch of things I had it do before the print. It paused the print, homed, attempted to z probe, then resumed the print. Obviously, it ruined the print.
      This behavior happens all the time and I don't think it's entirely a safari bug. Upon page reload, the duet goes though a cache of previously executed instructions. I don't know why it does this or how to stop it, but once I have the print running, it isn't safe to load the webUI again until it's done.
        Can you provide your firmware versions, DWC version, and Safari version?
        Does it do the same thing if you connect via Chrome?
          Mentaluproar
          WiFi Server Version: 1.21
          Web Interface Version: 1.22.6
          Safari version: 12.1
          I'll have to try with Firefox and chrome later as I've already started the print again. From what I remember, loading in a different browser avoids the problem. It's like either safari sends the commands again on reload, or the webUI executes them again on reload.
            Interesting.
            I do notice that your wifi server version is a little out of date. Not sure it will matter but also worth a try.
              Mentaluproar
              Updated the wifi component to 1.23. Should I be looking for some kind of log to post here?
                Maybe @chrishamm has some ideas.
                Have you tried DWC 2 RC6?
                  Mentaluproar
                  I've had this error for a long time now and have come to accept its just part of using a duet, but every now and then it pisses me off enough to come here. The thing is, it can't be all that common a problem of it would have been found and fixed by now. I'm definitely not the only Mac user here, so I can't figure out what's so different about my usage for it the triggers this.
                    I'm a Mac user too, but not Safari. I think that's likely the source of the issue.
                      Mentaluproar
                      I loathe chrome. Vivaldi is too busy for me. Opera I trust even less than Chrome. Firefox is great, but its not my plan A. Safari just handles UX nicer. If I have to, I can use Firefox for the printer, but it seems unneccessary to use a separate browser just for a printer.
                        Well as a temporary work around using another browser might get you through, but I agree there should be some further investigation why Safari is behaving as it is.
                        • chrishammundefined
                          chrishamm administrators @Mentaluproar
                          @mentaluproar Sounds really strange to me - I see no reason why your printer would behave like that. I think a Wireshark dump of the network traffic while that glitch occurs along with your zipped /sys directory would be quite helpful to track this down. Any chance you can provide that?
                          Duet software engineer
                            I am wondering whether Safari could be re-sending previous commands when you reconnect, and whether that could be causing the problem.
                            • Danalundefined
                              Danal
                              I've never seen this with Chrome on Windows desktop, Chrome on Mac, Safari on iPad, Safari on iPhone. I use all of those regularly.
                              I will give Safari on Mac a try.
                                Mentaluproar
                                It just did it again on Firefox. I turned on the machine, and as soon as I connected to it from the browser, it started homing by itself. It had been unplugged for a while too.
