Cant Get Board Setup PLEase HELPPP!!!
Please help me and contact me at Brandon019349@gmail.com. I have gotten everything set up I believe but when i try to get on to the web controller it says "Check that the SD card is mounted and has the correct files in its /www folder"
your board should have come with an sd card that has the correct structure.
see this to set it up manually
https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure -
The problem is that I dont know how to set any of this up. I bought this off someone and they didnt give me any of the information on how to use it. Never used a Duet controller before and it doesnt have the LCD panel anymore either
I have followed the directions to set it up so many times and still cant get it to work.
@brandon019349 said in Cant Get Board Setup PLEase HELPPP!!!:
Are you able to mount the SD card on your computer and insure the correct files are in place?
post a directory listing of all files and folders on the sd card
How do I do that?
assuming that you are using windows something like this
https://smallbusiness.chron.com/list-files-hard-drive-53547.html -
im using Macbook
it looks like the DWC was updated to some 2.0 beta version.
save the /www folder and replace it with the content of
DuetWebControl.zip
from
https://github.com/dc42/RepRapFirmware/releases/tag/2.03 -
So the 1.2.2 version one?
Does everything else seem to be in order for everything to work. Not sure how to set up by BLtouch either
and also where do i go from here to get everything started up?
I got the web controller up but now it wont home Z
Its like it doesnt know the bed is there and i dont know how to make it use the bltouch instead of the head
why dont you start by telling us what printer you have. what its currently running.
there are step by step guides on how to set up a duet.
for example here is one for the ender 3
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37 -
I have an ender 3 but the guy that i got it from added lots of stuff like the bl touch
There isnt really a guide for Ender 3 with bl touch Duet 2 Maestro and micro swiss hotend.
@brandon019349
ender 3 and ender 3 pro are close enough.then you go on to set up the bltouch using this helpful page
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probeand the micro swiss hotend might just be a different thermistor.
@veti said in Cant Get Board Setup PLEase HELPPP!!!:
This is the issue Im having. I dont understand any of this stuff so i don't understand half the stuff they are saying to set it up. Thats why i need help
As @Veti has said start with the manuals that Phaedrux has written, they are a godsend.
I can give you my config for the BL Touch.
As it says the Microswiss is a hot end, it only heats.
Just need to know which thermistor is in it.I can drop my Maestro code before I put the DD Extruder on it, but not until later.
P.
I have gotten to the web controller and have read all manuals I can find and still don't understand how to get this to work. I feel stupid that I don't understand this stuff but I dont and need more guidance than words on a manual that doesnt go into depth at all
Brandon. 3d printing is not something that just works. you will need to invest a lot of time in it.
there are many people start of like you. there are a lot of guides written and made on youtube.so please invest the time. read the guide. then come back with a list of things that you do not understand and ask them here.
we will try and help you understand them. but a general "i dont understand half of it" is not helpful because we dont know which half you dont understand.setting up a printer is just a start. you will need to test out a lot of different settings to get a good print quality. this takes time and involves reading and learning every step of the way.
+1 on this
