issues after upgrading to RRF3.2 beta3
@dc42 , @chrishamm, I'm pointing out the issues I'm experiencing after upgrading to RRF3.2 beta3:
-it seems that thermistor and heater on the expansion board are not recognizedError: M308: Unknown sensor type name "thermistor" Warning: M950: Sensor number 3 has not been defined
-a nozzle cleanup file is not detected within sys when present but it runs (in RRF3.2 beta2 it was working properly)
Warning: Macro file clean_nozzle.g not found
-printing is finished before you start (the bed and heater remain active). I have to restart the printer because in your opinion the print file is still active
Finished printing file 0:/gcodes/SANDING.gcode, print time was 0h 2m
-this error i don't understand what it refers to
Error: Failed to get macro response within 8000ms from SBC (channel File)
I attached report immediately after print end error:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-beta3 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6JKF0-3S86T-9A5YD Used output buffers: 6 of 40 (28 max) === RTOS === Static ram: 122124 Dynamic ram: 140868 of which 88 recycled Never used RAM 129112, free system stack 122 words Tasks: Linux(ready,73) HEAT(blocked,296) CanReceiv(blocked,869) CanSender(blocked,346) CanClock(blocked,352) TMC(blocked,20) MAIN(running,713) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:03:23 ago, cause: software Last software reset at 2020-11-07 16:33, reason: User, none spinning, available RAM 129152, slot 2 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task Linu Error status: 0x00 MCU temperature: min 25.1, current 25.5, max 25.6 Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Driver 0: position 2996, standstill, reads 3060, writes 30 timeouts 0, SG min/max 0/1023 Driver 1: position -23796, standstill, reads 3061, writes 30 timeouts 0, SG min/max 0/1023 Driver 2: position 33685, standstill, reads 3064, writes 28 timeouts 0, SG min/max 0/1023 Driver 3: position 0, standstill, reads 3060, writes 33 timeouts 0, SG min/max 0/979 Driver 4: position 0, standstill, reads 3070, writes 24 timeouts 0, SG min/max 0/168 Driver 5: position 160401, standstill, reads 3077, writes 17 timeouts 0, SG min/max 0/0 Date/time: 2020-11-07 16:36:44 Slowest loop: 8000.23ms; fastest: 0.11ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 371, MaxWait: 48748ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 72, completed moves 72, StepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.6 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages sent 882, send timeouts 879, longest wait 1ms for type 6042, free CAN buffers 47 === SBC interface === State: 0, failed transfers: 0 Last transfer: 19ms ago RX/TX seq numbers: 6294/6296 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x20aa0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-beta3 File: Finishing macro clean_nozzle.g, started by M98 P"clean_nozzle.g" > Next stack level Suspended code: G92 E0 Suspended code: G1 X0 Y160 Z0.15 F2000 Suspended code: M82 ;absolute extrusion mode Suspended code: M117 P"rinting..." Suspended code: M82 ;absolute extrusion mode Suspended code: M83 ;relative extrusion mode Suspended code: M83 ;relative extrusion mode Suspended code: G10 Suspended code: ;LAYER_COUNT:150 Suspended code: ;LAYER:0 Suspended code: M107 Suspended code: M204 T1000 Suspended code: M566 X720 Y720 Suspended code: G0 F2400 X16.46 Y-23.203 Z0.2 Suspended code: M204 P750 Suspended code: M566 X480 Y480 Suspended code: G11 Suspended code: G1 X18.744 Y-21.761 E0.09209 Pending code: G1 X21.156 Y-20.333 E0.09556 Pending code: G1 X23.55 Y-19.006 E0.09332 Pending code: G1 X26.008 Y-17.733 E0.09437 Pending code: G1 X28.442 Y-16.557 E0.09216 Pending code: G1 X31.006 Y-15.408 E0.09579 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 31.86 File /opt/dsf/sd/gcodes/SANDING.gcode is selected, processing
I attached the config.g file that has not been changed since the previous version. For the moment I'm going back to work in standalone mode. I would like answers as soon as possible.
config.g -
I am having similar issues after updating to beta 3 - My M308 calls for pt1000 or thermistor are "unknown" and fails out other heater/tool creation. Toolboard+main board are both Beta3.
@Marco-Bona, I'm sorry to hear that you are experiencing problems. Do you have similar problems in standalone mode, using 3.2beta3?
@dc42 ,unfortunately I'm using RRF3.2 beta2 in standalone mode because I have work to finish. If you want tomorrow I can do a check with beta3 so i can give you feedback, I hope positive........
Given the previous problems I've had, is it possible that my raspberry has a problem? -
@dc42, I confirm that the problem of thermistors also occurs in standalone mode on RRF3.2 beta3
@Marco-Bona said in issues after upgrading to RRF3.2 beta3:
Thanks for testing this. Did you check using M115 that the tool boards were running 3.2beta3 as well as the main board?
@Luke-sLaboratory said in issues after upgrading to RRF3.2 beta3:
Very strange, I am running a Duet 3 with two tool boards and I don't see any errors. Please provide our config.g file.
Does the error message appear again if you re-run M98 P"config.g" ?
@dc42, I verified that the main board and expansion board were on RRF3.2 beta3.
The config.g file is attached in the first post below. If you find any errors please report it to me so as to avoid unnecessary error reports.
Another point that I find strange, in standalone mode I can see messages with "echo" command on panel due while in SBC mode nothing is displayed on panel due or even on the DWC screen, is it a known problem? -
I've just managed to reproduce the "unknown sensor type" on an expansion board, but not yet on a tool board. I am looking into it now.
Another point that I find strange, in standalone mode I can see messages with "echo" command on panel due while in SBC mode nothing is displayed on panel due or even on the DWC screen, is it a known problem?Is the echo command inside a while-loop ?
@dc42, excuse me but I use an expansion board, not a toolboard
Yes I saw that; but Luke has a similar problem with a tool board.
I have located and fixed the problem with EXP3HC boards reporting unknown temperature sensor type and updated the Duet3Firmware-EXP3HC.bin file at https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2beta3. This issue only affected EXP3HC boards.
Thanks for the file. I'll ask @chrishamm to take a look.
@dc42, Thank you. I would like to go into the problem of SBC mode in more detail. If necessary, I remain available to carry out tests
@Marco-Bona, I think the issue is that when running with attached SBC, if output is generated inside a while-loop then DSF does not report that output until the entire loop has completed. We found this on Friday but we didn't want to hold up the release any more. Your bed.g file contains several echo commands inside while-loops.
Until this is fixed, the workaround is to use M118 to output the messages instead of echo.
@dc42, the issues that worry me most are those related to the "Assertion failed" error which is from the downgrade to version 3.1.1 that are bothering me and this "Error: Failed to get macro response within 8000ms from SBC (channel File)" which I cannot understand what it refers to. I look forward to your feedback so that we can correct the mistakes and work in total serenity. I believe that duet boards work properly, unfortunately I have no way to verify the proper functioning of raspberry, I would also be willing to replace it if it may be necessary as many users seem to be not going to give problems. I believe that duet cards work properly, unfortunately I have no way to verify the proper functioning of the raspberry, I would also be willing to replace it if it may be necessary as many users seem to be not going to give problems. Let me know, thank you again.
Marco -
To be clear: the "Assertion failed" only occurred after you downgraded to 3.1.1. Correct?
I will ask @chrishamm to look at the "Failed to get macro response within 8000ms from SBC" error. When do you see that error? If running a particular macro provokes it, please provide that macro file.
@dc42, The "Assertion failed" error began to occur with RRF3.2 beta2, then I tried to downgrade to beta 1 and finally to 3.1.1 but in both cases it continued to give problems. I do not understand whether it is a consequence or whether there is any other problem that occurred at that time.
I also tried to format and replace the sd card but nothing changed.
For this error " Error: Failed to get macro response within 8000ms from SBC (channel File)" it seems that it concerns the clean_nozzle.g file that I allege, initially if I remember correctly it was (channel daemon) or something similar. I had to delete the daemon.g file which contained a voltage check because it was repeated every 10 seconds.
Remember that the file clean_nozzle in RRF3.2 has no problem, I am still using it in standalone mode. I check in the morning if with beta3 in standalone mode it creates problems and I let you know.
clean_nozzle.g
