Duet2 wifi Not connecting
The duet supports WPA2 only.
I have 2 separate names for the 2 and 5 and I am on 2
I do understand what you are saying but stumped on why the connection isn't working
@dc42 Ok, so I did a test and made a dummy wifi account or link and was able to connect my board to the dummy wifi, which the wifi light stayed solid but it disconnected my internet. I connected to my internet and the light stayed solid blue but I could not get an IP address to pop up. I even typed in the wifi IP address to see if the DWC would pop up but it didn't. I am thinking there is a disconnect because of the providers security or mine.
Yes it sounds like a problem with the providers router settings. It has occasionally been reported before with ISP provided routers. You might be able to contact the ISP and explain the situation and maybe they can guide you on what to change, so some people have added a small cheap wifi extender as an access point for the printer.
I noticed in the feed back from the board that it says talnet disabled. what does that mean
RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.05.1 dated 2020-02-09b1<LF>
<LF>
Executing config.g...HTTP is enabled on port 80<LF>
FTP is disabled<LF>
TELNET is disabled<LF>
Done!<LF> -
https://en.wikipedia.org/wiki/Telnet
telnet is protocol used to get command line access to a system over a network. Not really relevant here.
ok so I just talked to the service provider and there are no security that would prevent the board from connecting. The only other thing I can think is that I need to use macro to enter the SSID and password. I'm not sure what I gotta do to do that
Put the SD card in your computer
Use a text editor to create a file
Enter the command M587 S"NETWORKNAME" P"PASSWORD" into the file with your network name and password.
Save the file as addwifi and save it to the macros folder on the SD card.
Put the card back in the duet and power it on by connecting to usb
Use YAT to send the command M98 Paddwifi
That will run the macro and try adding your ssid and password
The send m552 S1 and see if it connects.Just because they say there is no security stopping it doesn't mean that it will work. There could be other technical reasons preventing it that were just not aware of.
not sure how to get to text editor.
note pad on windows
Is that normal for Wifi vcc 3.33, reset reason turned on by main processor
yes that's normal.
on my duet2 board the 3.3v light is red not green
Hey this is what things say as of now for my Duet2 wifi-WiFi module is trying to connect<LF>
Failed messages: pending 0, notready 0, noresp 0<LF>
WiFi firmware version 1.23<LF>
WiFi MAC address 98:f4:ab:cf:be:21<LF>
WiFi Vcc 3.33, reset reason Turned on by main processor<LF>
WiFi flash size 4194304, free heap 28112<LF>
Socket states: 0 0 0 0 0 0 0 0<LF>
ok<LF>
M587<LF>
Remembered networks:<LF>
MySpectrumWiFiF8-2G IP=192.168.1.1 GW=0.0.0.0 NM=0.0.0.0<LF>
ok<LF>
WiFi reported error: Failed while trying to connect to MySpectrumWiFiF8-2G<LF>
WiFi module is idle<LF>
WiFi module is idle<LF> -
Can I upgrade firmware from 2.05.1 / wifi firmware version 1.23 if I can not get onto my WCB?
ok so I created a access point which isn't connected to the internet however I typed in my IP address and the control board popped up and the blue light is on to my wifi but I can not get my WCB to connect
@Tisum1979 said in Duet2 wifi Not connecting:
Where did you get that ip address? Are you sure it's correct?
You mean on your router, or with the Duet itself as an access point?
Yes you can, but I would suggest getting connected first and doing it from the DWC if at all possible.
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
