    Laser turns off after following code is sent after M3
    Laser Cutters
    9
    42
    1663
    • ericlmccormick
      ericlmccormick last edited by
      I have messed around for about 2 days trying to figure out how to correctly run my laser from the Duet 2 wifi board as a tool running along side by extruder using a 24 PSU for controls and 12V PSU for my heated bed and laser.
      There is a quick flash when I first go into laser mode which I am fine with. The unit turns on and off and changes power as I have expected based on giving it different codes. However I have one huge issue that boggles my mind. As soon as the next line of g-code is sent, the laser turns off. I can manually tell it to turn on with a M3 command but as soon as I tell the system to move in any direction, the laser turns off.
      Please help! the following is my setup
      Hardware:
      I have the 12VDC from the PSU to the laser control board and then negative terminal of the control board to the E1- terminal. Then I have the TTL+ pin of the control board going to HEATER3 (pin 8 of the expansion board). This is so the fan on the laser doesn't run all the time since it is powered on as long as the control board has power.
      Software:
      In config.g file
      M307 H2 A-1 C-1 D-1 ; Set E1 Heater logic to laser
      M307 H3 A-1 C-1 D-1 ; Set Heater3 logic to laser
      M452 P2 R255 F200 ; Set Laser Mode E1 Heater
      M452 P3 R255 F200 ; Set Laser Mode Heater3
      M451 ; Return to FFF mode
      M563 P2 S"Laser" ; Assign Laser to tool 2
      G10 P3 X50 Y0 Z0 ; Laser axis offset
      In Macro for laser mode
      M452 P2 R255 F200 ; Set laser mode for E1
      M3 s255 ; Set power to laser on
      M452 P3 R255 F200 I1 ; Set laser mode for HEATER3
      T2 ; Select Tool 2
      M3 S0 ; Make sure laser is off
        Which firmware version are you using?
        As a safety measure, the firmware will turn off the laser if the motion system runs out of GCode commands to process. This should not normally happen when you are "printing" from SD card.
        A more modern way to control the laser is to use the S parameter on the G1 commands to set the laser power. This is supported in firmware 2.02. Caution: you need to change your homing files to use H parameters on G0/G1 commands instead of S.
        • ericlmccormick
          I am using the newest firmware that was just released, 2.02.
          It isn't running out of gcode commands. The problem is that as soon as I send another command, the laser turns off. If I am in the g-code console and I send a M3 S1 signal, it turns on to the lowest setting, but if I then send a message in the machine console to move in a direction, it turns off.
          If I run a g-code file, there are times where turning a travel move the laser is told to turn off and then turn on again. Each time the M3 code is sent, the laser turns on for a split second. The control board only likes to see 5V PWM/TTL signals. Is there a different pin on the board besides HEATER3 that I can use that might not have this issue? Should I skip the control board all together and run the laser from E1 heater?
          For reference, the laser is 5.5W.
          I made a slight modification to the system. It is now running fully on 12V so the board is providing all power and no longer directly from the PSU. Issue is persistent.
          • ericlmccormick
            Here is a segment of the gcode file I am using. Is there something I am missing?
            M05 S0
            G90
            G21
            G1 F3000
            G1 X78.027 Y53.1606
            G4 P0
            M03 S255
            G4 P0
            G1 F750.000000
            G2 X67.4647 Y58.2199 I3.2607 J20.3625
            G2 X61.308 Y68.2625 I13.9842 J15.4816
            G2 X60.6505 Y73.2702 I18.3579 J4.9575
            G2 X61.3345 Y78.3007 I19.2122 J-0.0508
            G2 X63.9352 Y84.1174 I20.1897 J-5.5369
            G2 X68.1532 Y88.8641 I17.4699 J-11.2768
            G2 X74.512 Y92.7553 I16.8015 J-20.3154
            G2 X77.7869 Y93.0201 I2.0283 J-4.7017
            G3 X78.3207 Y92.9989 I0.3174 J1.2641
            G1 X78.4301 Y93.1283
            G2 X79.0747 Y93.7511 I0.6232 J0.
            G2 X85.4415 Y92.8863 I-1.1045 J-32.0006
            G2 X88.8112 Y91.7702 I-4.9161 J-20.4871
            G2 X91.8733 Y90.1351 I-7.9239 J-18.525
            G2 X99.9914 Y79.6837 I-11.0149 J-16.9343
            G2 X99.9025 Y66.4387 I-19.1661 J-6.4941
            G2 X94.4483 Y58.2217 I-19.0985 J6.7584
            G2 X85.8249 Y53.6123 I-13.412 J14.7204
            G2 X81.6389 Y52.9782 I-5.5116 J22.2482
            G2 X78.027 Y53.1606 I-0.9673 J16.6973
            G1 X78.027 Y53.1606
            G4 P0
            M05 S0
            G1 F3000
            G1 X77.1071 Y56.4577
            G4 P0
            M03 S255
            G4 P0
            G1 F750.000000
            G1 X77.0617 Y56.5215 F750.000000
            G3 X76.4537 Y56.684 I-1.4259 J-4.1163
            G3 X75.9837 Y56.6826 I-0.2312 J-1.2096
            G1 X75.9401 Y56.5826
            G3 X76.7081 Y56.0991 I0.8778 J0.5425
            G3 X77.1071 Y56.4577 I0.0384 J0.3586
            G4 P0
            M05 S0
              In firmware 2.02 it is assumed that if you put the firmware into laser mode with M452 then you will use the G1 S parameter to set the laser power. This provides better control and synchronisation than using M3. If you want to go on using M3 to control the laser then I suggest you don't use M452.
              • ericlmccormick
                The plugin I have for inkscape generates code with the M3 commands. Could you recommend a plugin that generates using G1 S parameters?
                If I don't use M452, how would I set the E1 heater and Heater 3 to laser mode in order for the M3 commands to work correctly?
                  Both Smoothieware and GRBL use the S parameter to control laser power, so you could look for a plugin that works with one of those firmwares. If you can't find one, I guess I could add a parameter to the M452 command that selects how the laser is controlled.
                  • ericlmccormick
                    I will look around for a Smmothieware/GRBL plugin.
                    I'm confused on what I would change in the M452 command. I have set the P, R and F parameters and I don't see anything else besides inverting the signal that you can do with the command. From other places on the forum, it looks like people have had success using the M452 with M3 commands when using a fan pin to control. However, I need to use a 5V TTL signal. Is there something inherent to how the HEATER3 pin is controlled? Is there another pin I might try instead?
                      dc42 administrators @ericlmccormick last edited by
                      No there is nothing inherent to heater 3, it's just the first PWM-capable output on the expansion connector.
                      I'm wondering whether it would work to have M3 preset the laser power (without actually turning it on) in laser mode. Then the power you set with M3 would be used on subsequent G1 commands with no S parameter (but not on G0 commands). Do you think that would work for you?
                      Meanwhile you could try using CNC mode (M453) which lets you map M3 to an output for spindle motor control in a similar way to M452. Note, in CNC mode, G0 commands ignore the feedrate and always use maximum speed as set by M203.
                      • bishop86
                        bishop86 last edited by
                        Hi. Im using LightBurn for generating gcode. Most of preset machine have persistent power so gcode have S power only on change. It will be good if M5 lock the output so none of G1 movements turn on laser. M3 without without Sxxx could unlock laser with previously setup power or with S to set new power. But Laser would only turn on with G1 movement. If S is included in G1 new power is set up. G0 cannot reset power.
                        Now im using custom written program convert gcode. It reads line by line and if S power param is in this line i stor it, If G1 line without S i add S with stored power at the end.
                          dc42 administrators @bishop86 last edited by
                          @bishop86 said in Laser turns off after following code is sent after M3:
                          Are there any other firmwares that behave in this way?
                          devleon 1 Reply Last reply Reply Quote 0
                          • devleon
                            devleon @dc42 last edited by devleon
                            @dc42 I've tired a lot of software (lightburn, laserweb4, lasergrbl) in the last few days that generate GCode using G1 Xnnn Ynnn Snnn to set the laser power. However, as @bishop86 mentioned, the S parameter is only included when the S is supposed to change, meaning G-Code will look like this:
                            G1 X33.73 Y16.07 S255.00
                            G1 X36.89 Y19.23
                            G1 X36.94 Y19.30
                            G1 X36.96 Y19.38
                            This means that S is supposed to stick, and I doesn't do that currently. That's why @bishop86 wrote a script to append the S paramter to G1 lines that have it missing.
                            In the meantime, would you be able to share the script you wrote @bishop86 ?
                              Which firmware version are you running? The G1 S parameter is already sticky in 2.03beta2 (although I regard this as dangerous, and a very bad decision on the part of those who introduced the S parameter and made it sticky).
                              • devleon
                                @dc42 Oh, I haven't tried the beta yet, still running 2.02. Will give it a try in the next days!
                                  Advance warning: in 2.03beta3 the G1/G2/G3 S parameter will only be sticky if you add parameter S1 to your M452 command.
                                  • nelho
                                    nelho last edited by
                                    Hi @bishop86 it's possible to send me your program please ?
                                    Thanks
                                    • morokolli
                                      morokolli last edited by morokolli
                                      Any progress on this?
                                      I ran in same situation with following code with Release 2.04 (Duet 2) and 1.25 (Duet 06/085).
                                      Tested also with 3.0beta12 (2019-11-02b1) using M452 C"exp.heater3" Q200.
                                      Config is in attached file.config.g
                                      Seems that heater3 output is turned off.
                                      gcode:
                                      ;Project bugbug
                                      ; *** START begin ***
                                      G90
                                      G21
                                      M84 S0
                                      G92 X0 Y0 Z0
                                      G00 X0.0000 Y0.0000 Z5.0000
                                      ;No. 2: Engraving 1
                                      G00 X25.7569 Y48.9645 Z5.0000
                                      G00 Z0.5000
                                      G01 Z0.0000 F1200
                                      M3 S255
                                      G01 X19.7518 Y30.6457 F750
                                      ;bug hits here. previus move is lasered ok, next 2 moves not.
                                      ;if run line by line (pasting one by one to console) all works ok.
                                      G01 X1.1829 Y30.6942
                                      G01 X16.1260 Y19.5851
                                      M5
                                      G00 Z5.0000
                                      G00 X0.0000 Y0.0000
                                      M05
                                        @morokolli, I'll test that when I get time.
                                        Are you able to configure your GCode generator to generate S parameters on the G1 commands instead of using M3? That's the modern way of doing laser engraving, and it benefits from velocity ramping in RRF3.
                                        • morokolli
                                          Tested with S parameter -> works like it should.
                                          I had to ask from CAM software developer is it possible. I'm using ESTLcam at moment.
                                          Waiting answer from there also.
                                          • morokolli
                                            I did more testing.
                                            While using attached G-Code error hits in even with S255 parameter.
                                            First square is burned ok, then on another part start and goes well until light turns off after couple moves (somewhere around line 30-32) and comes back after next move.
                                            Using Release 3.0beta12
                                            Sample G-code:
                                            [0_1573400684875_peukku.nc](Uploading 100%)
                                              Did you select sticky laser power in your M452 command?
                                              Your file upload to this forum doesn't appear to have worked. Please try again.
                                              • morokolli
                                                Reload of sample and config.g.
                                                config.g.txt
                                                peukku.nc.txt
                                                  dc42 administrators @morokolli last edited by
                                                  @morokolli said in Laser turns off after following code is sent after M3:
                                                  config.g.txt
                                                  peukku.nc.txt
                                                  M452 C"exp.heater5" Q200 ; laser uses heater3 pin, PWM frequency 100Hz
                                                  You didn't select sticky laser power. https://duet3d.dozuki.com/Wiki/Gcode#Section_M452_Select_Laser_Printer_Mode
                                                  • morokolli
                                                    Still same thing while using:
                                                    M452 C"exp.heater5" Q200 S1
                                                    Here's video:
                                                    https://www.youtube.com/watch?v=2FMmwe_Vmpk
                                                    • morokolli
                                                      More debug info:
                                                      If F value in G1 F300 is more than F1015 All lines are done as they should. If i's lower, piece is missing. And if speed is added over F1200, next line starts to suffer. Hopefully picture explains better:
