DWC 2.0.0 broke my reverse porxy
Duet Web Control
    Nxt-1
    For a while, I've been running a NGINX based reverse proxy to access my Duet. Since I upgraded to DWC 2.0.0-RC2 (which looks great fyi) my setup seems to have been broken 😞 . Below, I've included the relevant part of my config file. What has changed since the previous DWC/what am I doing wrong?
    server {
            index index.php index.html index.htm;                                   # possible index files
            location = /dwc/ {
                    proxy_pass http://192.168.178.147/;
                    proxy_set_header Host $host;
                    proxy_http_version 1.1;                                         # http protocol for the destination
                    proxy_set_header Upgrade $http_upgrade;                         # allow upgrading the connection
                    proxy_set_header Connection "connection_upgrade";
                    client_max_body_size 0;                                         # required to allow uploading the gcode files
                    proxy_request_buffering off;                                    # prevents buffers, for best performance
    Duet3D and delta printer enthousiast. Buildlog
    Looking for Duet3D configuration support, check out Nxt-3D
      Jacotheron
      Up to now, I have not run it in proxy mode, since there was bound to be issues.
      I have now tried it, and as you say there are issues. The ones I was able to find:
      • hard-coded http links - I have reported this in the other main thread. While you can change this yourself, if you will only be using it in https mode, by hard-coding it to https, the better option would be to create an If statement that looks for (location.protocol != 'https:') and then using http, and otherwise, use https.
      • The new interface have addresses that look like folders, for example Macros are at /Files/Macros on the Duet. I am not sure how well a path is translated using the reverse proxy detail you and I had. I added a new location that look like:
      location ~/(.*)$ {
                      proxy_pass http://{name.local or ip}/$1;
                      proxy_set_header Connection "upgrade";
      The idea is that we 'catch' everything after the first "/" as variable number 1 ($1) and then append it to the server, after the first "/"
      There may be other issues as well, just have not found them yet.
      To manually change the hard coded http links, you need to extract the gzipped javascript (inside the js folder), to reveal the actual .js file - you can then edit it in your favorite text editor. A sample of code that should result in the correct result (supporting both options, using the ternary operator) is (location.protocol == 'http:' ? "http://":"https://") - the idea is to replace the string "http://" with this everywhere it may be required. Finally remember to gzip it again and upload the new files.
        Nxt-1
        I realize this tread is quite dusty by now, but did you ever manage to get the Nginx revere proxy to work with DWC2 @Jacotheron? I'v recently gotten to trying again, but I have only gotten the same results as with your config but done differently. The webpage/UI loads, but no the JS's do not get loaded, thus no connection to the Duet is established.
          Jacotheron
          I haven't looked at this recently, since DWC 2.0 is currently is RC and I have removed my proxy pi for preparation for a local expo I am headed to.
          How I would go about to try again, is to get it like we had it before, and then go through the http logs on the pi as well as the web browser console (you get when you go to Inspect Element etc). Typically they should contain the cause of errors (for example missing javascript file), and then specifically target the issues found.
          undefined 1 Reply Last reply 30 Jun 2019, 16:01 Reply Quote 0
            Nxt-1 @Jacotheron
            @jacotheron There are two issues that I can see, hardcoded http and missing JS.
            0_1561910467467_32247e15-f577-4953-9586-ec52009227a0-image.png 0_1561910408772_c22a2765-c461-48cf-a9d3-32139bfcb263-image.png
              wilriker
              I have a reverse proxy setup to connect to my Duet from remote and it works flawlessly with DWC 2RC7. I remember there being an issue with reverse proxy in earlier release candidates and I don't remember which one actually fixed it but it works now.
              Though I have to say I only use HTTP (encryption is implemented over an SSH tunnel) and a subdomain in my specific setup:
              server {
                      listen 80;
                      server_name duet.localhost;
                      # Some upgrades here to be (able to be) more efficient
                      # Tell upstream where this request is coming from
                      proxy_set_header X-Real-IP $remote_addr;
                      proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                      proxy_set_header X-Forwarded-Proto $scheme;
                      proxy_set_header X-Forwarded-Host $http_host;
                      location / {
                              proxy_pass http://192.168.178.22;
                              proxy_set_header Host $http_host;
                              # Don't limit upload size and pass it on immediately without buffering
              EDIT: Regarding HTTPS I just create a Pull Request that replaces the hard-coded http: by location.protocol as mentioned by @Jacotheron.
              Manuel
              My Tool Collection
