    SD Card failure
    Firmware installation
    1.8k
    • duncan-rtfmundefined
      duncan-rtfm
      My SD card is not recognised by the Duet board, or either of my two laptops. To all intents and purposes, it's dead.
      • Vetiundefined
        Veti
        does the card show up in windows disk managment? it might just be a corrupt partition
          duncan-rtfm
          Hi, I've had this before. The card is not even recognised by Windows. The only acnowledgement it receives is a message saying that the card is not recognised.
            duncan-rtfm
            So basically, I need to build a new card. I have the card, and I have the files. I just can't figure out how to get the files onto the card.
              A Former User @duncan-rtfm
              @duncan-rtfm said in SD Card failure:
              OK, I've found this site: https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents but I have no idea how to actually download the files. Clicking on them opens up their contents. There is no download button.
              https://github.com/T3P3/Duet/blob/master/Duet2/SD Card Contents/SD_Card_Contents.zip
                Format the card as FAT32 (or if needed open the disk manager and create a partition on the card, format it and assign a drive letter)
                you should have a removable drive that is accessible under My Computer after the step above, then just copy the files accross.
                  Download the SD card files as a .zip file as @bearer shows 2 posts up. Then extract the files from that zip file to the root of the SD card. If your PC runs Windows 10, see https://www.simplehow.tips/a/56/how-to-zip-and-unzip-files-in-windows10.
                    A Former User
                    (Files other than .zip wil have a similar button that may saw "Raw" that will allow you to download individual files off GitHub, but in this case the zip file is the convenient way to do it.)
                      duncan-rtfm
                      Hi. I have downloaded the zip file, unzipped them into the root of a new SD card, and inserted it into the Duet board. I switched the power on, but there is no light which comes on to show that the WiFi module is active. And navigating to its IP address results in a time out error message. I'm running out of ideas.
                      duncan-rtfmundefined 1 Reply Last reply Reply Quote 0
                        duncan-rtfm @duncan-rtfm
                        @duncan-rtfm
                        The Wifi was working flawlessly till the SD card died. Do I just copy the files onto the card? Nothing else? How does the board know that boot files are there? Does the SD card need any special partitions or boot files? How does it even know to read what's on the card when it fires up?
                          Phaedrux Moderator @duncan-rtfm
                          @duncan-rtfm The SD card doesn't need anything fancy. It's just an SD card. The only thing that needs to be there are the folders and the config files. The main system files that the duet uses are located in the /sys folder. Config.g is read at startup and all the gcode commands within it are executed to configure your printer.
                            duncan-rtfm
                            OK, it sounds then like my WiFi card has somehow given up the ghost again. What commands can I issue from YAT to verify it is OK and healthy?
                              You can manually reset the wifi module if you have console access via USB, or a PanelDue. Send M552 S0, to disable networking, followed by M552 S1 to enable networking. When you do so, you should see the blue led on the wifi module blink a few times and then go solid when it has a connection. If the light is off, and stays off, that would mean there is a problem. In that case, send M122 to get a diagnostic report. The wifi part is towards the end, and may provide some insight.
                                duncan-rtfm
                                OK, Here's what happens...
                                M552 S0
                                ok
                                M552 S1
                                Turn off the current WiFi mode before selecting a new one
                                ok
                                M122
                                • WiFi -
                                  Network state is starting
                                  WiFi module is disabled
                                  Failed messages: pending 0, notready 1, noresp 0
                                  ok
                                  Do you happen to know what main and wifi firmware versions you are running?
                                    duncan-rtfm
                                    M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
                                    Board ID: 08DGM-917DA-G4MS8-6JKD6-3SN6N-9TVB9
                                    Used output buffers: 1 of 20 (10 max)
                                    And then a bit lower down:
                                      duncan-rtfm
                                      The SD card is fine. Works on my laptop...
                                        duncan-rtfm
                                        This doesn't make sense...
                                        M552 S0
                                        ok
                                        M552 S1
                                        ok
                                        M552
                                        WiFi module is being started
                                        ok
                                        M115
                                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                                        ok
                                          What does it respond when you send just M552?
                                            duncan-rtfm
                                            M552
                                            ok
