    I can't get the wifi to work
    Firmware installation
    • andrea518undefined
      andrea518
      First of all I admit that I am not an expetro in gcode.
      Second, i cant' run the wi fi on my duet 2 wifi, here are the tests that i've done :
      Upgrade duet to the lastest fw
      Install it on the correct order ( M997 S0:1:2)
      Make sure to send the correct instruction ( M587 S"xxx" P"xxx")
      I paste here some dialog, maybe you understand better than me.
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SD-6J1F8-3S86Q-1BMZF
      Used output buffers: 1 of 24 (10 max)
      Static ram: 25680
      Dynamic ram: 93244 of which 816 recycled
      Exception stack ram used: 288
      Never used ram: 11044
      Tasks: NETWORK(ready,1304) HEAT(blocked,1236) MAIN(running,3792) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:01:36 ago, cause: power up
      Last software reset time unknown, reason: Unknown, spinning module Platform, available RAM 10672 bytes (slot 0)
      Software reset code 0x00b0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20004adc Task 0x4e49414d
      Stack: 0044cdbf 0044cbd4 61005000 00000000 4074e600 00000000 00000000 3331bb4c 40000000 3f317200 b5ddea0e 388aa908 bb35fe81 3c4192f5 00000000 00000000 3f800000 00000000 00000000 60000010 0044ce71 20002c48 ffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 47.1, current 47.4, max 47.5
      Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 180801538
      Slowest loop: 99.68ms; fastest: 0.06ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === DDARing ===
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "m122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.26ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is changing mode
        WiFi module is idle
        Failed to get WiFi status
        m115
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
        ok
        WiFi reported error: no known networks found
        WiFi module is idle
      m552 s0
      ok
      M587 S"APE1" P"AndreaPozzetto9"
      ok
      m587
      Remembered networks:
      APE1 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
      ok
      m552 s1
      ok
      WiFi module is idle
      m552 s0
      ok
      M588 S"*"
      ok
      ok
      m552 s1
      ok
      WiFi module is idle
      • fcwiltundefined
        fcwilt
        How far away is the access point you are trying to connect to from the Duet?
          andrea518
          3 meters, i also tried another access point and tried turning my phone as acess point.
          • MrsDelishundefined
            MrsDelish
            Be sure the network is 2.4GHz and not a 5GHz one, since the 8266 module only do 2.4GHz iirc.
              Also please confirm that the SSID of your AP is exactly APE1, and that is it not set to hide the SSID. SSIDs are case sensitive.
              If it is set to hide the SSID, you will need to connect like this:
              M552 S1 P"APE1"
              instead of plain M552 S1.
                A Former User
                have a look in your config.g file to see if you have the same issue as the other have had lately?
                https://forum.duet3d.com/post/107325
