    Duet Ethernet Connection Dropping
    Firmware installation
    1
    • BMMalundefined
      BMMal
      Over the last couple of weeks I have been having difficulty with my Duet Ethernet dropping connection. I have frequently updated the firmware to development and release versions. I just updated to the newest V2 release this morning, including the appropriate DWC. Below is a diagnostic output. I have tried both Chrome and Edge with the same problem. Oddly, I am able to upload large files from the Cura addon but not able to complete uploading of any files through DWC. I have not seen any packet loss when trying to ping the printer either. I have a ticket in with the IT department here to see if there are any network related issues as well but thought I would see if there is anything obvious here too.
      I can establish a connection for a short period of time (maybe 10 seconds) and then it drops, reconnects, and repeats.
      11/4/2019, 11:05:33 AM M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet Ethernet 1.02 or later + DueX5
      Board ID: 08DDM-9FAM2-LW4SD-6JTDL-3S86R-KJW3X
      Used output buffers: 3 of 24 (19 max)
      Static ram: 25680
      Dynamic ram: 93868 of which 0 recycled
      Exception stack ram used: 440
      Never used ram: 11084
      Tasks: NETWORK(ready,628) HEAT(blocked,1176) DUEX(suspended,160) MAIN(running,3768) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:03:54 ago, cause: software
      Last software reset at 2019-11-04 11:01, reason: User, spinning module GCodes, available RAM 11108 bytes (slot 3)
      Error status: 0
      Free file entries: 8
      MCU temperature: min 26.9, current 27.1, max 27.4
      Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Date/time: 2019-11-04 11:05:32
      Cache data hit count 540492097
      Slowest loop: 2.63ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 23, completed moves: 23, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.7
      Segments left: 0
      Stack records: 4 allocated, 1 in use
      Movement lock held by file
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "M116 P0" in state(s) 0 12
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 8.59ms; fastest: 0.04ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      Duet Ethernet - Most likely the most recent Edge firmware
      Duet X5
      7" Panel Due V2
      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
      • BMMalundefined
        BMMal
        I just noticed that I often get an invalid password message when it disconnects. I disabled the password and this has stopped. Now, I am getting "Network error, failed to get file list." Or just "Connection Interrupted Network Erro."
        Duet X5
        7" Panel Due V2
