    Reboot loop with MPU enabled
    Beta Firmware
    • gtj0undefined
      gtj0
      This is a continuation of an earlier thread...
      @dc42 Now when I boot with the SBC connected, I get a boot loop. It happens somewhere in the middle of processing config.g with a "Controller has been reset" message.
      The end of the M122 output may be a little wonky because it was also capturing the GCode output from config.g
      M122
      RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12+1 running on Duet 3 MB6HC
      Board ID: 08DGM-9T66A-G63SJ-6J9F4-3SD6S-1U03B
      Used output buffers: 1 of 32 (5 max)
      Static ram: 122240
      Dynamic ram: 167708 of which 0 recycled
      Exception stack ram used: 212
      Never used ram: 103056
      Tasks: NETWORK(ready,2068) HEAT(blocked,1456) CanReceiv(suspended,3804) CanSender(suspended,1480) CanClock(blocked,1464) TMC(suspended,256) MAIN(running,4492) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:00 ago, cause: software
      Last software reset at 2019-11-10 09:11, reason: Memory protection fault, spinning module GCodes, available RAM 101704 bytes (slot 1)
      Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x04432804 BFAR 0x00000086 SP 0x20415c9c Task 0x4e49414d
      Stack: 00452a63 0043baf0 81000000 00000000 0042a57b 20422404 20424f38 00000004 0046e568 20423d00 00000000 01000000 00000000 0042b091 00000000 00000000 00429c25 00000000 20422300 20423d00 0043ae01 00000000 20415e2a
      Error status: 0
      Free file entries: 10
      MCU temperature: min 70.0, current 8.9, max -284.0
      Supply voltage: min 0.9, current 1.0, max 1.0, under voltage events: 0, over voltage events: 0, power good: no
      12V rail voltage: min 0.3, current 0.3, max 0.4, under voltage events: 0
      Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Slowest loop: 2.16ms; fastest: 0.17ms
      Hiccups: 0, FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Stack records: 1 allocated, 1 in use
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is assembling a command in state(s) 0
      daemon* is ready with "M122" in state(s) 0 0, running macro
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      spi is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.24ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      - Ethernet -
      State: 0
      === CAN ===
      Messages sent 0, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 13ms ago
      RX/TX seq numbers: 45063/5
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 20/180-0
      === Duet Control Server ===
      Duet Control Server v1.1.0.5
      Daemon:
      => 596 bytes
      > Suspended code level
      Code buffer space: 3500
      Configured SPI speed: 2000000 Hz
      Full transfers per second: 9.85
        I'm sorry, I no longer have symbol files for that build. Please try the firmware now at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 and assuming the problem still occurs, post the M122 report again. Also please post your config.g file as I suspect that some command in it that is missing from my config.g may be triggering the reboot.
        • gtj0undefined
          gtj0 @dc42
          @dc42 It looks like that build fixed it.
