    Branches required for 2.04
    Firmware developers
    • ctundefined
      ct
      I am trying to build 2.04. I have tried various branch combinations but keep getting error:
      Duet3D\RepRapFirmware\src/RepRapFirmware.h:185:2: error: '__set_BASEPRI_MAX' was not declared in this scope
      What are the correct branches to build this version?
        You need the dev branch of everything, except for FreeRTOS which has no dev branch. The definition of __set_BASEPRI_MAX is in the CoreNG project, file asf\thirdparty\CMSIS\Include\cmsis_gcc.h.
        • ctundefined
          ct
          Thank you for that clarification. I am now getting error:
          ../src/Platform.cpp:1312:8: error: no match for 'operator!' (operand type is 'SerialCDC')
            dc42 administrators @ct
            That's because you are using a version of CoreNG that is later than the one used by 2.04. Either revert CoreNG to an older commit, or update the RepRapFirmware project to latest and build 2.05RC1 instead.
            • ctundefined
              ct
              I am new to the project. I can find the RepRapFirmware versions. How do I identify which is the 2.04 commit of CoreNG? Can you please direct me to older commit.
                @ct said in Branches required for 2.04:
                You need the latest commit of CoreNG that pre-dates the 2.04 release. https://github.com/dc42/RepRapFirmware/releases/tag/2.04 says it was released "29 days ago" on 1 Nov. The commit log for CoreNG shows that the latest commit on or before 1 Nov was this one https://github.com/dc42/CoreNG/tree/392fed2e1423e0c949d7e21a993539087bffc088.
                ctundefined 1 Reply Last reply Reply Quote 0
                • ctundefined
                  ct @dc42
                  @dc42 Thank you for your help.
