    Duet3 Logging with M929: incomplete entries
    Beta Firmware
    • tooundefined
      too
      I am trying to enable Logging on the Duet3, and if I enable it through M929 P"logging" S1 the logfile seems inclomplete:
      2019-12-02 11:30:39 Event logging started
      2019-12-02 11:30:51
      2019-12-02 11:30:51
      2019-12-02 11:30:51
      2019-12-02 11:30:52
      2019-12-02 11:30:52
      2019-12-02 11:30:52
      2019-12-02 11:30:52
      2019-12-02 11:30:52
      2019-12-02 11:30:52
      2019-12-02 11:30:52
      2019-12-02 11:30:53 Finished printing file 0:/gcodes/dir_testing/one.g, print time was 0h 0m
      2019-12-02 11:31:40 Warning: Firmware halted
      2019-12-02 11:31:40 Warning: Firmware reset imminent
      2019-12-02 11:31:40 Warning: Controller has been reset
      2019-12-02 11:31:40
      2019-12-02 11:31:40
      2019-12-02 11:31:40
      2019-12-02 11:31:40
      2019-12-02 11:31:41
      2019-12-02 11:31:41
      2019-12-02 11:31:41 Warning: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C.
      2019-12-02 11:31:41
      2019-12-02 11:31:41
      2019-12-02 11:31:41
      2019-12-02 11:31:41
      What are all those empty entries, did I miss a step when configuring the logging?
      Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
        I presume you are running with a RPi connected, not in standalone mode. Which version of DSF are you using?
        tooundefined 2 Replies Last reply Reply Quote 0
        • tooundefined
          too
          Board: Duet 3 MB6HC (MB6HC)
          DSF Version: 1.1.0.5
          Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12+1 (2019-11-11b1)
          Board EXP3HC firmware 3.0beta1 2019-11-08b2
          • tooundefined
            too @dc42
            @dc42 any idea why that is happening? Could it be because of the pre-release RRF I am running?
            • tooundefined
              too @dc42
              Did anyone else successfully use event logging on the Duet3?
              • chrishammundefined
                chrishamm administrators
                Thanks, I'll fix it in the next DSF version. If you encounter more issues with DSF, please report them at GitHub.
                Duet software engineer
