    Laser power adjustment/speed
    Laser Cutters
    2.4k
    • clearlynotstefundefined
      clearlynotstef
      Wow this post has been so helpful! I will be following the progress with lightburn integration closely, I'm so excited to hear that you're already working on it. RRF has the potential to be outstanding with laser as it is with filament!
      Best,
      Stefan
        clearlynotstef
        Do you have any idea of when Lightburn compatibility might come to fruition? I'm so happy to hear that you were working on it, but I can't get a sense of if its moving along or just something that was discussed and left alone.
        Thanks,
        Stefan
          dc42 administrators @clearlynotstef
          @clearlynotstef said in Laser power adjustment/speed:
          Thanks,
          Stefan
          LightBurn compatibility in what sense? I am fairly certain that firmware 2.03 and 3.0beta are already compatible with LightBurn. The difference is that 3.0beta implements velocity ramping.
          • TonyPagettundefined
            TonyPagett
            Do I need to activate this velocity ramping or does it just work as is when in laser mode?
              dc42 administrators @TonyPagett
              @TonyPagett said in Laser power adjustment/speed:
              RRF3 implements velocity ramping when in laser mode, provided that you specify the laser power using S parameters on the G1 commands. So you don't need to enable it in Lightburn. RRF2 does not.
              TonyPagettundefined 1 Reply Last reply Reply Quote 0
                TonyPagett @dc42
                @dc42 Thank you.
                My next question is this. The following code moves the laser (CNC) in the defined square but only switches the laser on for the first line (or one side of the square).
                M3 S255
                G1 Y75.0000 Z0.01000 F2500.0
                G1 X75.00000
                G1 Y25.00000
                G1 X25.00000
                M03 S0
                If I add an S command to each line it works OK
                Is there a way round this?
                  Select "laser power sticky" in your M452 command. Preferably, don't use M3 to set the laser power, just use a S parameter on the first G1 move.
                    TonyPagett @dc42
                    How do I do this?
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M452_Select_Laser_Printer_Mode
                        TonyPagett @dc42
                        @dc42 You put "Laser power sticky" in M42 .
                        That's what threw me 😁
                          Sorry about that!
                            TonyPagett
                            Not a problem 🙂
                            It would appear that I am on RRF2 as I am using a WorkBee from Ooznest so the velocity ramping is not useable 😞
