Manually resuming print after shutting off.
Duet Web Control
    PeterA
    Hi all. Thanks in advance. Can someone point me in the right direction. We have constant power outages (load sheading) since I know when its happening I want to know if I pause the print then power off, can I then resume after 2 hours after powering back on. ? I've already found that the power outage aut resume does not save and resume so I was hoping to do it manually?
      Yes you can pause and power off, It should save the required information when you pause. Then follow the normal steps for resuming.
      https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
        PeterA
        thanks i'll give it a go.
        1 out of 3
