    RRF3 / Duet3 with Pi: execute bash through M code
    Firmware wishlist
    729
    • Danalundefined
      Danal
      You can also send gcode to a telnet session on any Duet. Of course, it must be enabled.
      Therefore, I'd imagine you can send G-Code to a telnet 127.0.0.1 on the Pi in a Duet3 configuration (I have not tested this). And many scripting languages will let you open a telnet equivalent and send to it.
      • wilrikerundefined
        wilriker @Danal
        @Danal said in RRF3 / Duet3 with Pi: execute bash through M code:
        Unfortunately, this won't work.
        Manuel
        My Tool Collection
        • tooundefined
          too @wilriker
          @wilriker thanks, I will look into that!
          I guess I will start learning go then 👍
          Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
          • Danalundefined
            Danal
            Is 127.0.0.1 not working because telnet does not yet work from anywhere in D3?
            Or is that a long-term thing?
            • wilrikerundefined
              wilriker @too
              @too said in RRF3 / Duet3 with Pi: execute bash through M code:
              Go is a great language! My preferred one by now. 👍
              Manuel
              My Tool Collection
              • wilrikerundefined
                wilriker @Danal
                @Danal OK, maybe we have to distinguish here a bit. Duet 3 running in standalone-mode, i.e. without a SBC attached does have HTTP, FTP and Telnet (optionally) available and will respond to it when enabled. That's just like Duet 2 does. But once you use Duet 3 with a SBC all network traffic will be handled by the SBC - which is simply Linux. DuetSoftwareFramework does not (and IMHO should not) implement Telnet or FTP protocols. It only provides HTTP support via DuetWebServer (based on .NET Kestrel server). So if you are trying to connect to the SBC via FTP or Telnet there has to be a service to accept these connections - but then you will communicate with the SBC like if you would open such a connection to any other Linux machine.
                Manuel
                My Tool Collection
                • Danalundefined
                  Danal @wilriker
                  @wilriker said in RRF3 / Duet3 with Pi: execute bash through M code:
                  If I read this correctly, an SBC equipped D3 has no Telnet support equivalent to D2 telnet support. Ever.
                  Interesting design choice. I do understand the logic/reasoning behind it, just as you've explained it. Nonetheless, setting all that reasoning aside, i.e. from "outside", an existing capability goes away. Specifically IP-of-printer:23 is a telnet that accepts G-Code.
                  Hmmm... Normal Linux FTP server could be easily configured to 'appear' to be just like the D2 FTP, by way of simply pointing the default directory to the virtual SD... or set it to default to other places on the Pi. End-user choice, easy via configuration on the Pi.
                  Is there any Linux standard way to do the same with Telnet? Somehow configure the Pi so that it 'appears' that telnet to port 23 reaches the Duet just like it always did?
                  Of course, there are other configurations where telnet would reach the Pi, which we'd likely keep turned off in favor of ssh for reaching the Pi itself.
                    It would be perfectly possible (and probably straightforward) to take a Telnet client and have it talk to the API provided by DSF. But Telnet is horribly insecure, so it would be much better to implement SSH or another secure alternative.
                    • Danalundefined
                      Danal @dc42
                      @dc42 said in RRF3 / Duet3 with Pi: execute bash through M code:
                      Completely agreed. But there it is on D2. Hmm....
                        dc42 administrators @Danal
                        And it's disabled by default. And we tell users not to make a Duet accessible to the Internet without using a VPN.
