    Bed leveling dual Z motor programming
    Duet Web Control
    • hbrownellundefined
      hbrownell
      I have the same bed size they describe in the "Bed levelling using multiple independent Z motors" article,
      ( https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors)
      ... The code looks like the following for config.g
      M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
      M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      ... Here is the bed.g code
      G28 ; home
      M401 ; deploy Z probe (omit if using bltouch)
      G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      M402 ; retract probe (omit if using bltouch)
      so I'm thinking I'll just copy/paste into my config.g and bed.g files. My question is, where should they go in the file? Should I put them at the top of the "Drive" section?
      My current config.g looks like this (With questioned areas noted);
      M569 P0 S0 ; Physical drive 0 goes Backwards
      M569 P1 S0 ; Physical drive 1 goes Backwards
      M569 P2 S1 ; Physical drive 2 goes forwards
      M569 P3 S0 ; Physical drive 3 goes forwards
      SHOULD I PUT THE CODE HERE?!
      DO I NEED TO CALIBRATE EACH STEPPER MOTOR INDEPENDENTLY?
      M92 X99.9 Y100.1 Z399.6183 E100 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z4000.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X1100.00 Y1100.00 Z1100.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X210 Y210 Z200 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M574 Z1 S2 ; Set endstops controlled by probe
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X34.82 Y-8 Z0.073 ; Set Z probe trigger value, offset and trigger height
      M557 X0:200 Y15:200 S50 ; Define mesh grid
      M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      M501 ; Load saved parameters from non-volatile memory
      Set idle timeout Same question for the bed.g file.. Thank you! I'm rather hopeful this will solve the extrusion issue and get to printing.
      • SIamundefined
        SIam
        @hbrownell said in Bed leveling dual Z motor programming:
        G28 ; home
        if you dont use a bl touch remove the M402
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
