    Reume after m601 pause not performing as expected
    Duet Web Control
    duet 3 hc6 3 extruder 1 hotend pause.g resume.g duet web control
    2.2k
    • tsunaminautundefined
      tsunaminaut @Danal
      @Danal Sorry Yes ribbon cable, g code is below
      G1 F1200.000
      G1 X36.795 Y43.354 E9.52794
      G1 X36.771 Y43.475 E9.53077
      G1 X36.747 Y43.597 E9.53311
      G1 X36.730 Y43.835 E9.53663
      G1 X36.730 Y56.927 E9.69288
      G1 X36.763 Y57.252 E9.69678
      G1 X36.782 Y57.347 E9.69873
      G1 X36.818 Y57.402 E9.70003
      G1 X36.835 Y57.424 E9.70055
      G1 X36.975 Y57.585 E9.70432
      G1 X39.744 Y60.379 E9.76438
      G1 X39.759 Y60.399 E9.76469
      G1 X39.763 Y60.407 E9.76480
      G1 X39.767 Y60.411 E9.76485
      G1 X39.771 Y60.414 E9.76490
      G1 X39.822 Y60.441 E9.76544
      M106 S229.5
      G1 Z1.700 F7800.000
      M117 PAUSE HAPPENS HERE
      M601
      G1 E4.76544 F2400.00000
      G92 E0
      G1 Z2.700 F7800.000
      G1 X39.542 Y43.201
      G1 Z1.700
      G1 E5.00000 F2400.00000
      G1 F900.000
      G1 X39.322 Y43.292 E5.00808
      G1 X39.201 Y43.385 E5.01323
      G1 X39.043 Y43.004 E5.02717
      G1 X39.503 Y43.004 E5.04273
      G1 X39.531 Y43.142 E5.04748
      G1 E0.04748 F2400.00000
      G92 E0
        tsunaminaut
        That was it! I just needed to insert M226! thanks Danal!!!! 3 days I was dreading having to ask someone lol!
          The other command you can use for this purpose is M600. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M600_Filament_change_pause.
            tsunaminaut
            So I was wrong that m226 didnt resolve the behavior. Basically it seemed to use the pause and resume scripts but then it squirts some plastic on the spot the pause happens circles around and goes back to pause. another oddity it seemed to retract T1 when I was using T0 although none of the gcode appears to have a tool change in it.
            https://www.youtube.com/watch?v=3XeIBw7q12c
            • Danalundefined
              Danal
              I don't use pause a lot, so I could be wrong... but... this looks to me like two different pause commands:
              One is "at byte" and the other is "at Xnnn Ynnn Znnn". Any chance the slicer has two different pause things enabled?
              What happens if you hit resume print again?
              tsunaminautundefined 1 Reply Last reply Reply Quote 0
                tsunaminaut @Danal
                @Danal I checked the slicer and there is no custom gcode in it aside from my tool change gcode which shouldn't be coming into play as I'm not changing tools in this test. When I click on resume, it does what that video shows every time over and over and over, like it starts running the code right before the pause m226 so just gets stuck in a loop, I checked the slicer and the only thing I'm seeing is the right click on layer 3 where I inserted M226. (had the same experience with m600 but I don't have any custom filament change g code file saved so am assuming m600 defaults to running my pause.g and resume.g). I checked the gcode file and it doesn't appear to have anything other then M226 in it either.
                  dc42 administrators @tsunaminaut
                  It may be a firmware issue. Are you running your Duet 3 with or without a Raspberry Pi connected?
                    tsunaminaut @dc42
                    @dc42 Running it with Duet web control through a raspberry pi 4 on the SBC 26 pin header.
                    Board: Duet 3 MB6HC (MB6HC)
                    DSF Version: 1.1.0.5
                    Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12 (2019-11-02b1)
                      @tsunaminaut said in Reume after m601 pause not performing as expected:
                      Thanks, I suspect it is to do with the way that DSF is handling M226 and M600.
                        tsunaminaut @dc42
                        @dc42 Is there a way of generating a log to see what commands are being sent by the pi? I'm pretty sure manually pressing the pause and resume buttons inside the web interface work as they should, it feels like upon resume its starting up again right before the pause in the code.
                        • Danalundefined
                          Danal
                          ssh to the pi, then:
                          sudo journalctl -u duetcontrolserver will dump the entire log; if to terminal with a 'more' like interface; if pipe or redirect, entire log.
                          sudo journalctl -fu duetcontrolserver with 'f' will follow (like tail -f) the log. You can leave this running while you try various commands, if you just want to see the log.
                          • chrishammundefined
                            chrishamm administrators
                            Please upgrade your DSF version and check if the problem perists. The print management has changed significantly since v1.1.0.5.
                            Duet software engineer
                              tsunaminaut @chrishamm
                              @chrishamm updated as follows
                              DSF Version: 1.2.3.0
                              https://www.youtube.com/watch?v=Pl8WEcgjPe8
                              Now M226 does the pause.g script when I hit resume it goes back to the print and throws error below
                              1/19/2020, 12:31:44 PM M24
                              Printing resumed
                              1/19/2020, 12:31:44 PM Printing paused at X114.2 Y113.1 Z1.3
                              1/19/2020, 12:31:44 PM Error: G1 has thrown an exception: [AggregateException] One or more errors occurred. (A task was canceled.)
                              1/19/2020, 12:31:44 PM Cancelled printing file 0:/gcodes/PRINTER_CANAL_v2PauseTestNew3.gcode, print time was 0h 2m
                                chrishamm administrators @tsunaminaut
                                @tsunaminaut I'm sorry you're still having an issue with that version. I believe this is fixed in DSF 1.2.3.1 which is available on the unstable package feed. To activate it, replace stable with unstable in /etc/apt/sources.list.d/duet3d.list and run a regular system update (sudo apt-get update && sudo apt-get upgrade).
                                  @chrishamm Im now on
                                  DSF Version: 1.2.3.1
                                  Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)
                                  The issue continues, it appears to be fixed on 1 single extruder print but once I put a pause in a print that has multiple extruders it goes back to doing the same thing as in the video from the above post.
                                  1/19/2020, 7:59:14 PM M24
                                  Printing resumed
                                  1/19/2020, 7:58:05 PM Printing paused at X72.4 Y117.9 Z0.5
                                  1/19/2020, 7:58:02 PM M24
                                  Printing resumed
                                  1/19/2020, 7:57:43 PM Printing paused at X72.4 Y117.9 Z0.5
                                  1/19/2020, 7:57:40 PM M24
                                  Printing resumed
                                  1/19/2020, 7:57:31 PM Printing paused at X72.4 Y117.9 Z0.5
                                  1/19/2020, 7:57:28 PM M24
                                  Printing resumed
                                  1/19/2020, 7:57:28 PM Printing paused at X72.4 Y117.9 Z0.5
                                    I've prepared another in DSF 1.2.4 which I will release shortly. It will allow you to pause prints wherever you want.
                                    Thanks for reporting this!
                                      @chrishamm @chrishamm Appreciate you looking into this thanks! Ill report back if 1.2.4 fixes this!
                                        tsunaminaut @tsunaminaut
                                        I installed 1.2.4 and now m226 just freezes the printer and it wont resume, also oddly now when I attempt to print files it prints the purge tower base and then just drops the bed untill it bottoms out and starts skipping my z motor. On another test print it was printing a skirt and halfway around it it just started dropping my z as well. I'm having trouble figuring out how to go back to a stable build. would you be able to share a link to the documentation with instructions for that, it would be appreciated as my printer is now unusable.
                                          @tsunaminaut Starting to think I have a defective board. I will get a file to print then half an hour later the next time I try to print the same file it just freezes for no obvious reason 1 minute in theres no error codeit stays hot, is there some limit on the size of files a duet 3 hc 6 can handle?. Also I cant find any documentation on how to get back to a stable build do I need to wipe everything out and start over again?
                                          1/28/2020, 1:17:00 AM M122
                                          RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0 running on Duet 3 MB6HC
                                          Board ID: 08DJM-956L2-G43S4-6JTDL-3SN6R-1S62G
                                          Used output buffers: 1 of 32 (6 max)
                                          Static ram: 152720
                                          Dynamic ram: 150320 of which 12 recycled
                                          Exception stack ram used: 536
                                          Never used ram: 89628
                                          Tasks: NETWORK(ready,1984) HEAT(blocked,1200) CanReceiv(suspended,3808) CanSender(suspended,1428) CanClock(blocked,1424) TMC(blocked,76) MAIN(running,4156) IDLE(ready,160)
                                          Owned mutexes:
                                          Last reset 00:12:16 ago, cause: software
                                          Last software reset at 2020-01-28 06:04, reason: User, spinning module LinuxInterface, available RAM 89628 bytes (slot 3)
                                          Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                                          Error status: 0
                                          Free file entries: 10
                                          MCU temperature: min 37.3, current 38.1, max 38.6
                                          Supply voltage: min 24.7, current 24.9, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
                                          12V rail voltage: min 12.3, current 12.3, max 12.4, under voltage events: 0
                                          Driver 0: standstill, reads 4095, writes 30 timeouts 0, SG min/max 0/1023
                                          Driver 1: standstill, reads 4096, writes 30 timeouts 0, SG min/max 0/1023
                                          Driver 2: standstill, reads 4105, writes 21 timeouts 0, SG min/max 0/792
                                          Driver 3: standstill, reads 4110, writes 17 timeouts 0, SG min/max 0/123
                                          Driver 4: standstill, reads 4113, writes 14 timeouts 0, SG min/max 0/0
                                          Driver 5: standstill, reads 4114, writes 14 timeouts 0, SG min/max 0/0
                                          Date/time: 2020-01-28 06:17:04
                                          Slowest loop: 3.62ms; fastest: 0.09ms
                                          Hiccups: 0(0), FreeDm: 315, MinFreeDm: 310, MaxWait: 459429ms
                                          === MainDDARing ===
                                          Scheduled moves: 349, completed moves: 289, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                          === AuxDDARing ===
                                          Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                                          Heater 0 is on, I-accum = 0.2
                                          Heater 1 is on, I-accum = 0.5
                                          Segments left: 1
                                          Movement lock held by null
                                          http* is ready with "M122" in state(s) 0
                                          telnet is idle in state(s) 0
                                          file* is doing "G1 X153.694000 Y154.263000 E0.010930" in state(s) 0
                                          serial is idle in state(s) 0
                                          aux is idle in state(s) 0
                                          daemon* is idle in state(s) 0
                                          queue is idle in state(s) 0
                                          lcd is idle in state(s) 0
                                          spi is idle in state(s) 0
                                          Code queue is empty.
                                          === Network ===
                                          Slowest loop: 1.13ms; fastest: 0.01ms
                                          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                          HTTP sessions: 0 of 8
                                          • Ethernet -
                                            State: 0
                                            Error counts: 0 0 0 0 0
                                            === CAN ===
                                            Messages sent 2951, longest wait 0ms for type 0
                                            === Linux interface ===
                                            State: 0, failed transfers: 0
                                            Last transfer: 14ms ago
                                            RX/TX seq numbers: 27156/21561
                                            SPI underruns 0, overruns 0
                                            Number of disconnects: 0
                                            Buffer RX/TX: 556/1940-0
                                            === Duet Control Server ===
                                            Duet Control Server v1.2.4.0
                                            File:
                                            Buffered code: G1 X153.694 Y154.263 E0.01093
                                            Buffered code: G1 X154.121 Y153.937 E0.03475
                                            Buffered code: G1 X154.369 Y153.815 E0.01786
                                            Buffered code: G1 X155.198 Y153.486 E0.05777
                                            Buffered code: G1 X155.585 Y153.297 E0.02785
                                            Buffered code: G1 X155.890 Y153.113 E0.02304
                                            Buffered code: G1 X156.754 Y152.483 E0.06922
                                            Buffered code: G1 X157.616 Y151.744 E0.07352
                                            Buffered code: G1 X158.648 Y150.809 E0.09015
                                            Buffered code: G1 X159.380 Y150.063 E0.06768
                                            Buffered code: G1 X163.268 Y145.845 E0.37137
                                            Buffered code: G1 X163.533 Y145.620 E0.02248
                                            Buffered code: G1 X163.784 Y145.458 E0.01938
                                            Buffered code: G1 X164.002 Y145.375 E0.01511
                                            Buffered code: G1 X164.668 Y145.584 E0.04513
                                            Buffered code: G1 X165.153 Y145.711 E0.03246
                                            Buffered code: G1 X165.696 Y145.777 E0.03541
                                            Buffered code: G1 X166.110 Y145.756 E0.02690
                                            Buffered code: G1 X166.484 Y145.695 E0.02449
                                            Buffered code: G1 X166.920 Y145.570 E0.02935
                                            Buffered code: G1 X168.305 Y144.986 E0.09736
                                            Buffered code: G1 X169.123 Y144.716 E0.05573
                                            Buffered code: G1 X169.809 Y144.543 E0.04582
                                            Buffered code: G1 X170.648 Y144.367 E0.05546
                                            Buffered code: G1 X171.354 Y144.269 E0.04619
                                            Buffered code: G1 X172.213 Y144.202 E0.05578
                                            Buffered code: G1 X173.781 Y144.252 E0.10157
                                            Buffered code: G1 X174.194 Y144.244 E0.02675
                                            Buffered code: G1 X174.613 Y144.163 E0.02757
                                            Buffered code: G1 X175.452 Y143.916 E0.05665
                                            Buffered code: G1 X175.672 Y143.887 E0.01438
                                            Buffered code: G1 X175.970 Y143.882 E0.01927
                                            ==> 1408 bytes
                                            Code buffer space: 2156
                                            Configured SPI speed: 2000000 Hz
                                            Full transfers per second: 29.65
                                            File /opt/dsf/sd/gcodes/18YodaRobes.gcode is selected, printing
                                          Log shows the following
                                          Jan 28 06:13:47 duet3 DuetControlServer[366]: [info] File: Finished macro file retractprobe.g
                                          Jan 28 06:13:47 duet3 DuetControlServer[366]: [info] Height map loaded from file heightmap.csv
                                          Print fails at this time so I am unable to cancel the print or abort it all I can do is emergency stop
                                          Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Firmware halted
                                          Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Firmware reset imminent
                                          Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Emergency stop
                                          Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Resetting controller
                                          Jan 28 06:17:38 duet3 DuetControlServer[366]: [info] Aborted print file
                                            @tsunaminaut Plesse share your sys directory and the file you have been trying to print. I have been unable to reproduce pause problems with 1.2.4 but I would really like to figure out why you still seem to have issues.
                                            For now, you may have more success using the Duet 3 in standalone mode, i.e. with a microSD card installed and without a Raspberry Pi.
