    Duet3 + Pi4 + HDMI Touchscreen virtual keyboard
    DSF Development
    8
    14
    1.1k
    • wilrikerundefined
      wilriker
      Other alternatives are onboard and florence. Both have an auto-hide feature. But I never used either keyboard and thus cannot say much about their auto-hide so YMMV.
      Manuel
      My Tool Collection
      • Dougal1957undefined
        Dougal1957 @Danal
        @Danal Tried the matchbox one and it doesn't pop up when needed.
        • Danalundefined
          Danal
          Yeah, I was afraid of that. apt-get remove it, and then try the ones @wilriker wilriker suggested.
            Dougal1957
            tried both onboard and florence bu didn't have any joy with themProbably my total ignorance when it comes to linux mind. so any other suggestions gratefully received?
            • KajRepundefined
              KajRep
              Hi.
              Maybe Chrishamm could put a keyboard into the next DWC.
              Kaj
              Kaj Rep
              • Mautundefined
                Maut
                Hi, not the best solution, but I'm booting into the duet web page using chromium in kiosk mode and using a virtual keyboard add-in for chrome.
                Still have some issues though... If you find something better I would like to know 🙂
                • gtj0undefined
                  gtj0
                  I've tried onboard and florence and while they worked OK in the native apps, they didn't work do well in chrome. So far the "Google Input Tools" extension works OK but you have to use the extension's menu to trigger the keyboard. The best one I've found is "Touch Kiosk Keyboard". There are several forks of this but the version I have is "third" generation version 1.11.3.
                  • DaBitundefined
                    DaBit
                    I have the Pi + screen in the front panel anyway, so to make it useful I tried setting up DWC using chromium-browser in kiosk mode:
                    #!/bin/bash
                    unclutter -idle 0.5 -root &
                    sed -i 's/"exited_cleanly":false/"exited_cleanly":true/' /home/pi/.config/chromium/Default/Preferences
                    sed -i 's/"exit_type":"Crashed"/"exit_type":"Normal"/' /home/pi/.config/chromium/Default/Preferences
                    /usr/bin/chromium-browser --noerrdialogs --force-device-scale-factor=0.7 --disable-infobars --kiosk http://192.168.0.42
                    Runs fairly OK:
                    Except for two things:
                    • The virtual keyboard. I had no luck using onboard and matchbox. I tried several Chrome extensions including 'Touch Kiosk Keyboard v1.11.3' and 'Virtual Keyboard' (which seems to be the same thing). It pops up, when I enter numbers or text the text appears in the DWC input field, but somehow I am unable to 'enter' the value/text. Not by pressing the 'enter' key in the keyboard, not by pressing 'send' if I want to enter a G/M code. It just does nothing.
                      This seems to be a DWC (2.0.6) thing; in other websites such as www.google.com it works.
                    • I would like to have a 'drag to scroll', like you do on Android. Cannot get that to work either.
                    Anyone got the above two things to work?
                    • Danalundefined
                      Danal
                      Wow, force scale < 1. You must have a physically big screen. I'm running scale 3 on a seven inch.
                      To your actual question: I have not looked at V keyboards yet, may do so this weekend.
                      • DaBitundefined
                        DaBit
                        Well, back in the days when our computer monitors used picture tubes I used to run 2048x1536 resolution on a Iiyama Vision Master 22" with font size 6 in the texteditor 😊
                        Nowadays my eyes are a bit older, but I find scale 0.7 on the Pi 7" screen far from uncomfortable. The only uncomfortable item in DWC with my sausage-shaped fingers is the Chromium scrollbar, hence the 'drag to scroll would be nice'.
                        • Danalundefined
                          Danal @DaBit
                          @DaBit said in Duet3 + Pi4 + HDMI Touchscreen virtual keyboard:
                          Cool!
                          By the way, "Drag to scroll" works for me. I do not use a bar at an edge, I just plop anywhere and drag; entire image moves like you were wheeling a mouse.
                          • danym21undefined
                            danym21
                            Has someone found a good solution?
                            Maybe someone with knowledge can inplement this?
                            https://mottie.github.io/Keyboard/
