    Problems with micro SD card on a ROSTOCK MAX V 3.2
    CNC
    1.1k
    • insertcoinundefined
      insertcoin
      hey everyone,
      My School recently purchased a DIY kit for the ROSTOCK MAX V 3.2 from seemecnc. This printer uses a duet wifi board, so i was wondering if i could get support here. I cannot use WIFI to connect to the printer, because school wifi policies don't allow it. My issue is that none of the files in the micro SD card inserted into the DUET can be read or show up on the LCD touchscreen we purchased from seemecnc. When i try to open macros, for example the macro NETWORK, i recieve the response: macro file "0:/macros/NETWORK" not found. i loaded these macros from the seemecnc github as instructed by the configuration guide. I tried different micro SD cards and formatting, but they just won't show up. However, when i connected the printer to MatterControl and ran my macros through MatterControl, they seemed to be working just fine. I have tried seemecnc support as well as MatterHackers, but nobody can help with my issue. The gcode that i load on the SD card that is inserted in the LCD touchscreen also seems to have a problem: When i click on the gcode file on the Touchscreen and file information pops up, all stats are set to 0 (print time, material etc.). I don't know whether this is an issue with my duet board or printer itself. By the way, This is the first #D printer i have ever built, i am very much new to this, and barely know what gcode is. Thank you so much.
        1. If your school won't allow you to connect the Duet to the school WiFi network, perhaps you can run it in access point mode instead? Caution, if you do that then anyone with the password will be able to connect to it from their smartphone.
        2. On PanelDue, as long as you are using compatible versions of PanelDueFirmware and RepRapFirmware, you can switch between listing the GCode files on the SD card in the Duet (Card 0) or the one inserted into PanelDue (Card 1) by pressing the SD card icon at the top of the file list. Is that working? The macro list is always fetched from card 0.
        3. If you move the SD card to a SD card adapter in a PC or laptop, is the file /macros/NETWORK visible in the PC?
        4. What firmware versions are you using? To find the Duet firmware version, send command M115 from the PanelDue Console or from MatterControl. To find the PanelDue firmware version, go to the Setup page.
          insertcoin
          on pc, the micro sd card and the sd cards have all the files loaded. They are visible and i can open/ edit them with notepad ++. How would i set up access point mode? I have looked at both sd cards through the lcd, that sadly is not working. I will send M115 right now and let you know what happened. Thanks!
            insertcoin
            M 115 returns FIRMWARE_NAME: RepRapFirmware for Duet Wifi.
            Also, what is panelDue?
            • Danalundefined
              Danal
              PanelDue is the touchscreen.
              insertcoinundefined 1 Reply Last reply Reply Quote 0
              • Danalundefined
                Danal
                That's all? Should show quite a bit more.
                Where/how was this? USB? or Touchscreen 'console' tab? or ?
                  insertcoin @Danal
                  @Danal thanks, i didn't even know that. When i put M 115 in the MatterControl terminal, that's all taht showed up. I am connected via usb to the printer.
                    insertcoin
                    After putting M 115 into the console, i get
                    FIRMWARE_NAME: RepRapFirmware for duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet Wifi 1.0 FIRMWARE_DATE: 2017-09-01
                      insertcoin
                      The panelDue firmware i am using is firmware version 1.22.1(28b1)
                      • Danalundefined
                        Danal @insertcoin
                        @insertcoin said in Problems with micro SD card on a ROSTOCK MAX V 3.2:
                        From your USB terminal
                        M552 S0
                        This should put the WiFi module in "reset" or "idle" mode.
                        M589 S"ssid" P"password" I"10.10.10.1"
                        This sets the WiFi module to AP mode. Use an SSID and Password that you like. (Do Not put this in config.g, it saves itself in the WiFi module)
                        M552 S2
                        This actually starts the WiFi module. It is OK to put this in config.g
                        A minute or so later, you can look for the SSID on your phone or tablet or whatever, and then connect to that network. Then connect to that IP address in a browser.
                        • Danalundefined
                          Danal @insertcoin
                          Fantastic that we got the full story!!
                          And... drum roll... that release is REALLY old.
                          Given your school environment, what permission is needed to upgrade? We can discuss exactly how after we determine what is OK and what is not OK.
                          • Danalundefined
                            Danal @insertcoin
                            That is also fairly old. And a slightly different upgrade procedure. Again, after you decide how you wish to proceed, we can discuss the details.
                              insertcoin
                              @Danal said in Problems with micro SD card on a ROSTOCK MAX V 3.2:
                              this returns "bad or missing parameter in M 589 command" . I do not have the school wifi password, and wouldn't be able to use it anyways, are you saying i should choose whatever i want for ssid and password? I can download any software on my computer, the only problem is that my school doesn't allow wifi access. I have no other restrictions. Thanks so much by the way!
                                insertcoin
                                How would i change the firmware updates?
                                • Danalundefined
                                  Danal @insertcoin
                                  By going AP, you are setting up a new network totally separate from the School's network. The ssid and password on this new network should NOT match the school, they should be your independent choice.
                                  How about:
                                  M589 S"rostocknet" P"pepperwool" I10.10.10.1
                                  The bad parm error was from quotes around the IP address.
                                  • Danalundefined
                                    Danal @insertcoin
                                    Step 1 is to get connected. 🙂
                                      insertcoin @Danal
                                      Okay, i feel like we're getting closer. After sending though, M552 S2, i get a Wifi reported error: failed to start access point.
                                      Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • Danalundefined
                                        Danal @insertcoin
                                        Hmmm... try M552 S0 wait a min, M552 S2, wait, try that a couple of times.
                                          insertcoin
                                          I tried that just now for a few times. I forgot to mention that "Wifi module is idle" shows up every time i get the wifi reported error, is that important?
                                            dc42 administrators @insertcoin
                                            That's because firmware 1.19.x didn't support access point mode. This is what I suggest:
                                            • Download iap4e.bin and DuetWiFiServer.bin from https://github.com/dc42/RepRapFirmware/releases/tag/2.03 and put them in /sys on the Duet SD card
                                            • Download Duet2CombinedFirmware.bin from https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1 and put it in /sys on the Duet SD card
                                            • Also put a copy of Duet2CombinedFirmware.bin on the SD card renamed to DuetWiFiFirmware.bin, replacing any existing file of the same name
                                            • Put the SD card back in the Duet and start the Duet
                                            • From Matter Control, send M997 S1
                                            • When that finishes updating the WiFi module firmware, send M997 (without the S1). It will disconnect.
                                            • After 30 seconds, try to connect again. Send M115 and check the firmware version. It should be 2.05.1.
                                            That will get the Duet firmware up to date. After that you can update the touch screen firmware.
