    Firmware rollback or other solution
    Firmware installation
    1.0k
    • Danalundefined
      Danal @dmbgo
      @dmbgo said in Firmware rollback or other solution:
      Would the Config file have been altered by the new firmware?
      Nope. It literally can't.
      • Danalundefined
        Danal
        Firmware Version: 3.0 (2020-01-03b3)
        V2 to V3 requires YOU to make fairly extensive changes to the config. If you are not ready to do that, install 2.05.1 from
        https://github.com/dc42/RepRapFirmware/releases
        using file Duet2CombinedFirmware.bin
        Once that is in and running, install DWC 2 (Duet Web Control 2) from here:
        https://github.com/chrishamm/DuetWebControl/releases
        Using file DuetWebControl-SD.zip. Do NOT unzip it, just upload the whole thing via the "system" tab "upload system files" button. The web interface will refresh itself as soon as the upload finishes.
        • dmbgoundefined
          dmbgo
          Thanks Danal
          I tried uploading and installing firmware V2.03 just then, which didn't fix things.
          Tool 0
          T0
          undefined
          n/a
          n/a
          0
          0
          Bed
          Heater 0
          off
          error
          0
          I'll try your suggestion and let you know what happens.
          Regards David Maher
          • dmbgoundefined
            dmbgo
            I downloaded both files that you suggested, then installed the firmware and web control. Voila! it seems to be fixed. My temperature values are as I'd expect, the error for the bed has gone and I am able to turn the heaters on and see their values change.
            Thanks a million.
            Regards David Maher
            • Danalundefined
              Danal @dmbgo
              Thanks a million.
              • dmbgoundefined
                dmbgo
                Printing away nicely now....
                Thanks again.
                Dave
                Regards David Maher
                • dmbgoundefined
                  dmbgo
                  Should I now investigate / make the changes necessary to upgrade to firmware V3? What is involved, is there a tutorial? I'd better pay attention this time. 🙂
                  Regards David Maher
                    Phaedrux Moderator @dmbgo
                    @dmbgo https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                    This will give you a taste.
                    In general though, if you're content to just print, stick with 2.05. But if there is a feature of RRF3 that you need, or you like to experiment and test, then updating now might be worth it.
                    You can use the web configurator to get a base config for RRF3 to start with. Then you may need to change a few things here and there manually.
                    • dmbgoundefined
                      dmbgo
                      Thanks Phaedrux I'll have a look. I was thinking that in future firmware upgades may need whatever this version needs.
                      Regards David Maher
                      • dmbgoundefined
                        dmbgo
                        Thanks Phaedrux
                        Now that I have looked, and had a skim read of the requirements, I realize that to upgrade to V3 is not a task to be undertaken lightly. I think I'll wait until there is a definite reason to upgrade.
                        Thanks for the link.
                        Dave
                        Regards David Maher
                          @dmbgo Yes RRF3 is going to be the future of the firmware. 2.05.1 is likely to be the last update for the 2.x versions. Which you can look at as being a long term stable release with no new features and maybe bug fixes. For the Duet 2 Wifi and Ethernet and Maestro boards that's not a bad thing since it's very feature rich already. But with things like conditional gcode in RRF3 it will open a lot of possibilities for doing some cool stuff with scripting and automation.
                          So for the time being, sticking with RRF2 is the sane thing to do if you just wanna print. RRF3 is you wanna mess around.
