Reinstall firmware on duet3, now no flashing led
USB does not give you network (web) connection. You need to plug a cable from the ethernet connector to your router/hub, OR, us a Pi for WiFi.
Bearer is correct... use the online config tool, then add M453 near then end of config.g. That will be very close, and you can adjust from there.
@bearer said in Reinstall firmware on duet3, now no flashing led:
isn't there a flashing led to provide some sort of visual sync indication for the can bus stuff?
Yes, and it was missing before because the card was NOT in "stand alone" due to missing /sys/config.g. When that file is not present, the card waits for an RPi to init it. No init = not running = no flash.
@Danal I have since attached an ethernet cable from the duet to my router and im still not seeing it show up under my devices when i log into my router
@chichirod said in Reinstall firmware on duet3, now no flashing led:
Your config.g needs to activate a network. Next step is to build out a sample with the RRF online tool, put that on the SD, power on, and see if it then appears.
@Danal did that, still nothing. I will open the config file to see what it says. Is there a certain command I should be looking for?
This section:
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet -
If you still have your USB terminal, you can enter M552 with no other arguments and it will show you network status.
@Danal Ok I didnt even have a section in the config file for network. Ill let you know
You should be able to directly copy/paste the above.
And... M552 (no args) on the USB terminal will show you your IP address
should I not be able to see the duet3 on DWC now.
in adittion to setting up the network as Danal helped you with you'd ofc need the DWC files on the SD card
@Danal We are getting there. First thank you guys for all your help. It gave me my ip address, however when I key it into by internet it says "Your Duet rejected the HTTP request: page not found
Check that the SD card is mounted and has the correct files in its /www folder -
@bearer I was just reading another forum about the DWC. I will put it on the card as well and try
@bearer No unfortunately still the same thing
you downloaded the DuetWebControl-SD.zip file and extracted it into www on the sd card?
@bearer no i just extracted it and put it on the card, I never created a www folder
@bearer Sorry to keep bugging but I have tried every way to get this DWC installed. I tried to create a www folder and install it in there, no luck. I tried to install it just in the sys file no luck. I tried putting just the contents of the DWC in the www folder no luck and a few other scenario's. im obviously missing something just not sure what.
DWC files should be in www in the sd card, as the error message you posted indicated.
maybe you can post the layout of your card
@bearer so when you open the card it shows the config file, then click on that and it takes you to the sys file and then
