    New edge firmware 1.18beta3
    Firmware installation
    8
    20
    3.1k
    • chrishammundefined
      chrishamm administrators
      @lolorc:
      @iDevelo:
      Nice. Is there any chance Chris could create a branch for the latest work on DWC and use tags so people can package from source?
      I can't agree more.
      no changelog, no commit log, no source, this is basically an improper way to distribute OSS software.
      A changelog including the source files for 1.15 have been pushed to my GitHub repository. The changes since 1.14 were quite vast and I didn't want to officially release a new version before I was sure they were all working, so it took a bit longer than I first expected. In general I agree, though, and will try to push my beta changes right to GitHub when I prepare a new version next time.
      Duet software engineer
      • iDeveloundefined
        iDevelo
        @chrishamm:
        @lolorc:
        @iDevelo:
        I can't agree more.
        Good man. Maybe tag each release as well? Keep up the good work!
        • lolorcundefined
          lolorc
          @chrishamm:
          @lolorc:
          @iDevelo:
          I can't agree more.
          Thanks a bunch ! 😉
          • ChrisPundefined
            ChrisP
            I've just tried updating my v0.6 board to 1.18beta3, however, when I try to load the web interface I'm given an error that the connection was refused.
            I can connect over USB and FTP without issue, and the terminal confirms that the HTTP port is enabled. I've updated the web interface to 1.15-b2 too.
            When I move back to 1.17d, everything is fine again. Any ideas?
              I presume this is on a Duet 06 or 085. Have you by any chance been using an HTTP port number other than 80?
              • ChrisPundefined
                ChrisP
                Indeed, it is a Duet 06 and I have tried M586 with and without an R parameter. When using R, I set the port to 80.
                I have also tried enabling debugging over usb and while I see many logs when connecting over ftp using 1.18beta3, or over http when using 1.17d, I get no logs when trying connect via http using 1.18beta3.
                I can provide logs if needed?
                  Strange, my Duet 06 is working just fine. I don't have any M586 commands in config.g.
                  • ChrisPundefined
                    ChrisP
                    Hmm, okay, I have another 3 at work using Duet 06 boards that I can easily test today.
                    I hadn't realised you could omit the M586 commands. I only really added it to enable FTP support which I use occasionally so I thought I might as well add the line for http too.
                      You don't need to use M586 commands if you only want http, because http (only) is on by default. I guess I should check that M586 P0 S1 in config.g doesn't actually turn http off!
                      • ChrisPundefined
                        ChrisP
                        So, I've just tried the same setup on my printer at work and like yours, it doesn't have any problems either with or without M586 P0 S1. I'm clearly missing something stupid on my setup at home. It's just bizarre that I have no problem if I load 1.17d, but it instantly becomes unresponsive with 1.18beta3. I shall have to keep digging.
                        • curieosundefined
                          curieos
                          I'm having a weird bug when printing in 1.18beta3. I sliced with KISS. When the printer goes to print the first line is good, but as soon as it gets to the first corner weird things start happening. I'm assuming its running into a step generation limit because it slows down a bunch and the extruder starts to fly, trying to rapidly extrude. I have no clue how to describe it, it seems to be following the correct path, but it is trying to extrude much more than it should?
                          I'm trying a print out on an older file, and after this I will try reloading the firmware and then try switching to relative extrusion in KISS.
                          EDIT: All was caused by KISS not including absolute and relative M codes.
                          She/Her
                          I work at a local 3D printing shop.
                          Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
                          • pkmundefined
                            pkm
                            Possible bug in 1.18beta3.
                            After a print is finished User-Defined Macros list is empty in Machine Control tab. I go to Macros tab and run a macros, then they all appear in Machine Control tab.
                              I think this is a general issue with DWC. After I connect, the list of macros on the Control tab is usually empty. If I switch to the Macros page and back, it appears. I don't need to run a macro to make the list appear.
                              • pkmundefined
                                pkm
                                On the contrary, I usually see the list after connection… Anyways, that's not a big deal.
                                • curieosundefined
                                  curieos
                                  Yeah, I have a similar problem. If I already had the page loaded from a previous connect and I'm not on the Machine Control tab, none of the macros show up. I haven't tried running one to get them to show up, normally I just dc and reconnect on the machine control page.
                                  She/Her
