    Switching from Stable to Unstable versions
    Firmware installation
    790
    • monsterundefined
      monster
      @bearer
      pi@beast:~ $ echo M997 S0| sudo /opt/dsf/bin/CodeConsole
      Connected!
      pi@beast:~ $
      WebUI up and
      Board: Duet 3 MB6HC (MB6HC)
      DSF Version: 1.3.2.0
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC7 (2020-04-14b3)
      Note: You can install updates on the System page.
        A Former User
        so all good?
        • monsterundefined
          monster
          I'm not sure.
          I tried to run this test macro (hoping that IF will work in RC7)
          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
              M300 S300 P200
          else
              M300 S100 P200
          And got: Code isn't supported
          And M300 S100 P200 is being sent to controller with no error replied, though no sound produced. This is new behavior.
          • monsterundefined
            monster
            Though homing happens...
              Conditional Gcode isn't yet supported on Duet3+Pi, but is coming soon.
              • monsterundefined
                monster
                I've been using M300 in debug purposes. Figuring out which *.g script just being run or in which part of the script printer now.
                In case M300 isn't producing any sounds anymore what would be my method to do this kinda feed back messages?
                  You can use M117. You can use object model variables in the M117 command if it helps.
                  • monsterundefined
                    monster
                    One finding since yesterdays RC7 installation.
                    I started to get (while homing) error message
                    G28 Z
                    Error: Code is not supported
                    And I started to figure out where do I have that command. (Btw according to https://duet3d.dozuki.com/Wiki/Gcode#Section_G28_Home that shouldn't cause any errors but anyway)
                    Then I did download all files from my system directory and searched for "G28" in all *.g files.
                    And I found one occasion "G28" (without Z parameter) in my start.g which isn't called during homing.
                    This is why I writing here is there a chance of a bug? That somehow "G28 Z" called automatically? Perhaps when WebUI "Home Z" pressed?
                    And why it does produce error message...?
                      dc42 administrators @monster
                      @monster said in Switching from Stable to Unstable versions:
                      Exactly. G28 Z should be recognised, it is equivalent to G29 Z0. The value of the parameter is ignored.
                      Are you sure that the error message isn't related to a different command? Although normally the command G- or M-code would be included in the error message.
                      • monsterundefined
                        monster
                        I took a screenshot to show that the error message appears by the end of homingz
                        Homing z code is below (sorry it is messy at the moment)
                        ; homez.g
                        ; called to home the Z axis
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Mar 30 2020 01:10:04 GMT+0300 (Eastern European Summer Time)
                        G91               ; relative positioning
                        ;G1 Z10 F500 		; lower the bed slowly because it can already be in lowest position
                        G90
                        M98 P"quickhomexy.g"
                        G90              ; absolute positioning
                        ;if move.axes[0].homed && move.axes[1].homed && move.axes[2].homed
                        ;	G1 H2 X150 Y150 Z15 F3000  ; move quickly to X and Y axis middle (where Z home trigger is) and at the same time bring Z to 15mm befor home spot
                        ;else
                        G1 H2 X150 Y150 F4000  ; move quickly to X and Y axis middle (where Z home trigger is) not moving Z
                        ;G1 H2 Z10 F2000    ; move quickly to 10cm away from expected home
                        G1 H1 Z-200 F500 ; move Z down until the endstop is triggered
                        ;G92 Z0            		; set Z position to axis minimum (you may want to adjust this)
                        G92 Z2.8
                        ;G91              ; relative positioning
                        ;G1 Z10 F2000       ; lift Z relative to current position
                        M117 "End of Z homing"
                        So I could say yes I'm sure.
                          Please post the contents of quickhomexy.g too.
                          • monsterundefined
                            monster
                            Quickhomexy.g
                            ; quickhomexy.g
                            ; called to home x and y axes
                            M117 "Quick homing X&Y begin"
                            G90
                            ;if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                            ;  M98 P"quickhomexy_doublepass.g"
                            ;else
                            ;  M98 P"quickhomexy_singlepass.g"
                            else
                            ;G1 H1 X-300 Y-300 F900  ; move slowly to X and Y axis endstops once more (second pass)
                            M117 "Quick homing X&Y end"
                            and
                            ;M98 P"quickhomexy_doublepass.g"
                            ;M291 P"Double"
                            M117 "Double pass X&Y homing"
                            G90
                            G1 H1 X10 Y10 F5000
                            G91
                            G1 H1 X-300 Y-300 F4000
                            G1 X10 Y10 F600
                            G1 H1 X-20 Y-20 F600
                            and
                            ;M291 P"Single"
                            ;M300 S200 P100 					; play beep - debug sound
                            M117 "Single pass X&Y homing"
                            G90
                            G1 H1 X10 Y10 F2000 	; move quickly to X and Y axis to 10cm away from expected home (first pass)
                            G1 H1 X-20 Y-20 F900  ; move slowly to X and Y axis endstops once more (second pass)
                            • monsterundefined
                              monster
                              by the way is "move.axes[0].max" is available in RC7 ?
                              Also is there way to define own constants? E.g. I could define X Y coordinates at witch magnet for Z endswitch is locates and refer to those constants in homing g files.
                                Yes.
                                Not yet, this is scheduled for firmware 3.02.
