Unable to connect on Windows 10 after installing drivers
Greetings,
I am a beginner so the answer may be something painfully obvious.
I purchased Duet 2 Maestro directly from duet3d a while back. Today I finally got to setting it up. I followed the Guide with the ID: 7, but after I manually installed the driver the device disappeared from Device Manager completely. So I defined a communications port just to check and checked for Windows updates. Nothing helped so I rebooted my computer. That did nothing as well.
This was on a notebook Lenovo G50-30 running windows 10.After that I connected the Duet board to a 8 year old Windows 7 desktop, but it did not detect the board at all.
When the board is connected to any of these PCs 3 LED turn on. One red next to the connector and a green and a red one on the edge of the board.
Thanks
@PaperakuZ said in Unable to connect on Windows 10 after installing drivers:
? I think some screenshots might be of help here.
How did it appear in device manager before it disappeared?
@bearer Before driver installation it appeared with a yellow triangle. After the installation the device with a yellow triangle disappeared I was not able to find a device which had the driver installed. Screenshot shows current device manager.
Thanks, can you open the properties for the device, go to the Details tab and find the Hardware Ids property and add that just to check the board reports the correct IDs for the drivers to attach to.
edit: migh as well throw in a picture of the Drivers tab too.
@bearer Which device?
the Communications Port (COM6) at the top of your picture, it is still there?
@bearer yes
Are those all the hardware id's? if so it's not the Duet board.
Looking for something similar to
@bearer The COM6 does not have any other hardware ids. The Generic USB Hubs have Hardware IDs similar to the ones you featured.
Edit: USB composite devices have these ids as well.
All USB devices should have something like that, thats how the hardware and drivers are tied togehter.
You're getting power to the board so presumably the problem is part of the USB connection. Try different USB port or different USB cables to see if it makes a difference.
@bearer I tried 2 cables with all ports before, but after you suggested it I tried a 3. and it worked. Windows told me installing new device: Duet.
Now I can continue, thanks and sorry for wasting your time for a bit. -
No worries, glad you got it sorted.
