    Javascript Error
    Duet Web Control
    • rickypilnikundefined
      rickypilnik
      I've recently started having a problem when I open up my config.g file I get disconnected and this error shows up.
      × JavaScript Error
      A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
      Version: 1.22.2
      Message: ResizeObserver loop limit exceeded
      URL: http://172.16.1.144/
      Line: 0:0
      Error object: null
      Everything else works - i.e I can print, send commands open other system files no problem, but the moment I open the config.g file I get disconnected....any ideas?
        Try upgrading DWC to 1.22.6.
          rickypilnik
          Worked a charm, thanks!
