Only follow the last movement command
I'm using a duet 2 Wifi/ethernet controller with RepRapFirmware version 2.03RC1 and I was wondering if the controller has several movement commands in it's queue, are there any command for only following the last command given and clear the rest?
Commands issued 1,2,3,4,5,6
At the moment 2 is executing, you issue ?? and the result is the Duet executes only 2? or completes 2 and executes only 6? or terminates 2 and executes only 6? Or something else?
And... generally... no. I know of no such command in Duet or any other G-Code.
The closest two things are:
- Emergency stop, that terminates the current move and doesn't start any more
- M400 which waits for the planner buffer to be empty before proceeding.
Neither of those seems all that close to what you are asking.
Terminates 2 and executes only 6 is what I'm looking for yes.
