    Higher microsteps 0.8.5
    Firmware installation
    • jmjcoke2undefined
      jmjcoke2
      If I use external drives can the 0.8.5 use higher microstep setting x32 - x256?
        If you use external drivers, then the microstepping is set on the drivers, not in the firmware. So it can be as high as the drivers allow and the Duet can generate steps fast enough for.
