    Duet 3 hc6 firmware wont write
    Firmware installation
    396
      A Former User @A Former User
      @bearer
      First thing i tried after no com port shown.
        A Former User
        After doing the bossa thing and pressing the reset button, it disapears from the com port selection
          @Torppa said in Duet 3 hc6 firmware wont write:
          in the device manager?
            @bearer
            yes
              A Former User
              It only shows as a Bossa port and after flashing firmware, it disapears compleatly, reset does not help nor does it make any sound when plugging to windows, there are 4 LEDs lit a green one and 3 red ones, bl touch does go up and down when pluggin the duet into the usb port.
                @Torppa does it go back to a bossa device if you place a jumper on the erase pins? If so I'd download the firmware again and repeat the flashing to rule out corrupt file (although I thought they had checksums on this now).
                You are using the correct binary right?
                  @bearer
                  It does and using Duet3Firmware_MB6HC.bin
                    A Former User
                    This goes well, untill i press Exit.
                    • Dougal1957undefined
                      Dougal1957
                      Have you installed the Duet drivers it appears from you screenshots that it has flashed successfully
                        i had some difficulties with the GUI version, the CLI version seemed to work might be worth a try
                          A Former User
                          Now lets call an exorcist, i plugged it to my wifes gaming rig and nothing hapened, then back to my workhorse and now it shows as a duet.
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-19b2
                          Is the DWC 2.0.4 still valid for the 3.1.1 version?
                            A Former User
                            This again.
                            M20
                            Begin file list
                            NONE
                            End file list
                            ok
                              A Former User
                              Well well well, when the machine is plugged to power sd card slot is way too hot, probe on multimeter tells me its 67C, might be bad soldering.
                              No wonder i have had problems here and there, better just start the lenghty fight with reprapworld.
                                If the SD card slot is hot, then it must be the SD card that is overheating, which means the SD card is faulty.
