    Error while building reprap firmware 3
    Firmware developers
    • Saurabhundefined
      Saurabh
      Hi @dc42 I'm trying to compile reprap firmware 3 for my duet3 board.
      I've donwloaded branches and using build configuration as given below.
      RepRapFirmware: v3-dev   - Duet3_V06
      CoreNG: dev  - SAME70
      FreeRTOS: master  - SAME70
      RRFLibraries: dev  - SAME70_RTOS
      DuetWiFiSocketServer: master
      CANlib : master   - SAME70
      but getting error as shown in screenshot.
      I've not made any changes in code.
        You need to roll back project RRFLibraries to the 3.1.0 tag, https://github.com/Duet3D/RRFLibraries/releases.
        • Saurabhundefined
          Saurabh
          That worked but now getting other linker errors. Multiple definition in networking.
          one of them is given below.
          Description Resource Path Location Type
          ./src/Networking/LwipEthernet/Lwip/out/build/x64-Debug/CMakeFiles/3.16.19112601-MSVC_2/CompilerIdC/CMakeCCompilerId.o:(.data.info_arch+0x0): multiple definition of `info_arch'; ./src/Networking/LwipEthernet/Lwip/out/build/x64-Debug/CMakeFiles/3.16.19112601-MSVC_2/CompilerIdCXX/CMakeCXXCompilerId.o:(.data.info_arch+0x0): first defined here RepRapFirmware
            The symbol "info_arch" is not used anywhere in RepRapFirmware. I see references to MSVC and X64-debug in your listing. Have you by any chance compiled the files using MSVC instead of gcc?
            • Saurabhundefined
              Saurabh
              @dc42 I was trying to add project in vscode. It was taking too much time create Makefile so left it in half. Thank you for the help Sir.
