    Small problem in need of fixing
    Duet Web Control wishlist
    • fcwiltundefined
      fcwilt
      I use a "type 5" Z-probe but the current web interface reports it as an unknown type.
      Be nice to fix this.
      • Jackalundefined
        Jackal
        What version of firmware are you using?
        • fcwiltundefined
          fcwilt
          Let's see…
          The main firmware is 1.18.1
          The WiFi firmware is 1.03-ch
          The WebControl firmware is 1.15a
          • Jackalundefined
            Jackal
            I seem to have misunderstood your question but I found the answer now.
            I think this part in DuetWebControl is outdated, we only have type 1-6 now.
            comm.js
            [c]var probeType;
            switch (status.probe.type) {
            case 0:
            probeType = T("Switch (0)");
            break;
            case 1:
            probeType = T("Unmodulated (1)");
            break;
            case 2:
            probeType = T("Modulated (2)");
            break;
            case 3:
            probeType = T("Alternative (3)");
            break;
            case 4:
            probeType = T("Two Switches (4)");
            break;
            default:
            probeType = T("Unknown ({0})", status.probe.type);
            break;
            [/c]
            • fcwiltundefined
              fcwilt
              Thanks for the info.
              I may have confused things by calling it a "type 5" which is how it is referenced on the DuetWifi web page for "Machine Properties" whereas the documentation on Z-probes refers to "mode 5".
              So is this something that will likely be fixed in the next release?
